Which is the correct way to filter/block traffic between vlans?
martin.germano
  Hi all. My question is: Which is the correct way to filter/block traffic between vlans?
i have a more than 15 vlans. I want to block traffic between them except 2 vlans.
source vlan 3 deny destination vlan 4
#access-list 100 deny ip 192.168.3.0 0.0.0.255 192.168.4.0 0.0.0.255
and the oposite:
#access-list 101 deny ip 192.168.4.0 0.0.0.255 192.168.3.0 0.0.0.255
I have to do this for all VLANs, ono by one. Is that right?
Thanks.
There are a couple of ways to achieve that. I assume that you have a Layer3-Switch. There I would configure one ACL per vlan-interface and allow/deny the traffic as you want. Sadly, the Switches don't support object-groups yet, so you have to use the IP-networks here. Only allow/deny traffic based on networks or hosts. Don't even try to be very granular with permit/denys based on ports. Because the switch-ACLs are not statefull you'll run into problems for the return-traffic if you woulf do that. And the return-traffic of course has to be allowed also.
Another way: with the help of 802.1x you can deploy port-based ACLs for every user. That takes some time for planning, but is one of the most powerful solutions.
For more control you could remove the L3-interface from your L3-switch and move that to your router or firewall. These devices support stateful filtering and you can control your traffic much tighter tehn with ACLs on the switch.
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
johnlloyd_13
Level 9
Level 9
Layer 2 VLANs are isolated from each other by default. You'll need a router to perform inter-VLAN routing for the said 2 VLANs.
  Hi karsten, yes I only have a layer 3 switch (no firewall, and no router avaiable). So, i think ACL-per-vlan is the best choice for me.
  Thanks for reply.
