which module can replace GLC-GE-100FX= ?
Arun More
                   Hi ,
I have to replace the GLC-GE-100FX= modules with spare ones available , can any one suggest me which can be used to replace this one with added advantages ?
Arun
Ivan Shirshin
Hi Arun,
What router or switch are you using it in? You can find the list of compatible transceivers by the platform or linecard here:
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Its 3750 G and other end 2950 . Distance is 350 meters with multimode cable
GLC-GE-100FX seems to be the onyl one compatible.
Kind Regards,
Ivan
Kind Regards,
Ivan
