12-25-2013 09:34 AM - edited 03-07-2019 05:14 PM
I have a R7600 with one active sup720-3B(512MB SP and 512MB RP Memory). So can I install one more sup720-3B(1GB SP and 1GB RP) for standby role? And which redundancy mode (RPR, RPR+ or SSO) when I install both supervisors on R7600?
12-25-2013 01:52 PM
In order for SSO to work, you need the have the same exact hardware on both Sups. Even if you get it to work with mismatch memory, it will take the lowest common denominator, which is 512 and 512.
08-22-2014 08:45 AM
I have the following SUPs, will I be able to do redundancy? Will I be able to upgrade the firmware?
5 2 WS-SUP720-3B Hw : 5.6
Fw : 8.5(2)
Sw : 12.2(33)SXI12
Sw1: 20.1(1)SXI9
WS-SUP720 Hw : 3.1
Fw : 12.2(17r)S4
Sw : 12.2(33)SXI12
WS-F6K-PFC3B Hw : 2.3
6 2 WS-SUP720-3B Hw : 5.8
Fw : 8.5(3)
Sw : 12.2(33)SXI12
Sw1: 20.1(1)SXI9
WS-SUP720 Hw : 3.3
Fw : 12.2(17r)SX5
Sw : 12.2(33)SXI12
WS-F6K-PFC3B Hw : 2.5
08-22-2014 09:26 AM
Yes, both Sups are the same. So, you should be able to upgrade and load the same version of IOS to both Sups and configure SSO for redundancy.
12-25-2013 05:58 PM
RPR if you the images does not match.
RPR+ having same IOS.
SSO having same hardware/software.
Take a look at following URL:
In NSF/SSO mode, one MSFC is active and the other MSFC is in a hot-standby mode. The hot-standby MSFC maintains a constant readiness state by receiving state information from the active MSFC. At any given moment, the standby MSFC may be called on by the supervisor engine to take over the responsibilities held by the active MSFC.
-In the above state, you can still access or session into standby MSFC.
RPR overview in 12.2(18)SXF
RPR is a cold standby mode. When a switchover occurs, the standby MSFC must go completely through its initialization. RPR mode is used primarily for the fast software upgrade (FSU). (See the
"Fast Software Upgrade" section
In RPR mode, the startup configuration is synchronized to the standby MSFC, however, it is not processed in any way until the switchover occurs. The running configuration is not synchronized to the standby MSFC.
Haihua
12-25-2013 07:36 PM
So in my case, two sups will be RPR+ redundancy mode, and I can switchover without causing linecards reloaded?
12-25-2013 08:20 PM
That it is correct. RPR+ is an enhancement in which the standby supervisor is completely booted and
line cards do not reload upon switchover.
Haihua
06-21-2016 06:36 PM
Hi, I am having a similar case with two redundant SUP720-3B with 512MB of RAM
I need to test a 1GB (RP and SP) RAM IOS in order to see if a bug disappear but i only have the memory for one supervisor. If the bug disappear then we will buy the memory for the other supervisor.
What can i spect from this scenario?
The documentation refers to IOS mismatch but no to RP and SP memory mismatch.
JP,
