04-11-2012 02:34 AM - edited 03-07-2019 06:04 AM
Good day,
I need a CISCO Switch... which have 12 ports for Fiber and 12 Ports for ethernet (gig ot 10gig).
kindly specify, whichn model is available, and which module have to use for fiber..
thankyou..
P.S. I have seen 3560,3750 datasheets , but didnt understand...
04-11-2012 02:53 AM
Hi Adnan,
There's probably several ways to do and it all depends on your requirements i.e.
Stackable?
Layer 3 or Layer 2?
PoE or non PoE?
Redundancy?
A quick example of stacked configuration would be:
1 x WS-C3750X-12S-S
1 x WS-C3750X-24T-S
That would give you two switches with the following port capacity:
12 x SFP (Can take a varity of CISCO SFP's (1000 Base-T - Copper or 1000-BaseSX - Fiber). - Switch 1.
24 x 10/100/1000 Copper Gigabit + Optional expansion slot.
Without looking at expensive chassis soluitions there isn't a Cisco switch that combines 12 SFP & 12 Copper interfaces in the same unit. You have to mix & match units or mix & match line-cards in a bigger unit.
Any questions let me know.
04-11-2012 03:04 AM
For that combination of 10G fibre and copper in the one switch you will need to look at the 4900M. See below:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
04-11-2012 03:11 AM
thankyou...sean
kindly read my reply to the duncan...
04-11-2012 03:09 AM
Thankyou duncan,
what i needed for, the switches...nothing to configure...actually have to use it as layer 2,but demand is Lyaer 3,
above all the options, i need only POE, doesnt matter stackable or not..
But having combination of both FIBER and Cat6 ethernet ports... if the combination is available like 12/12, then it will be good for me, other wise , have to buy multiple switches..
only ethernet and fiber ports..with poe..
04-11-2012 04:04 AM
Hi Adnan,
In that case I suggest the following:
WS-C3750X-24P-S, gives you 24 x Copper Gigabit with PoE.
and the:
WS-C3750X-12S-S to give you 12 SFP (Fiber) ports. - NOTE YOU WILL STILL NEED TO GBIC's SFP's as well.
Unfortunately as far as I'm aware there isn't a 12/12 combination in a single switch.
The above is only two switches to satisfy your requirements.
