Why did my 3560-E reboot?
stewartjs
Is there a show command that would show why the system restarted. Specifically if it was restarted by a user from the cli. I thought a show version used to tell you this, but I don't see it now.
5 Replies 5
bretjaquish
Level 3
Level 3
cisco WS-C3750-24P (PowerPC405) processor (revision J0) with 118784K/12280K bytes of memory.
Processor board ID CAT1030ZHB9
Last reset from power-on ----- This??
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
No, that appears if the power was unplugged or the system was restarted via CLI. I thought there used to be something more. Something like "system reload via system-restart command".
Syslogs should show:
*Mar 1 00:16:21.148: %SYS-5-RELOAD: Reload requested by console. Reload reason: Reload command
If you are using TACACS+, command history/accounting would also show you this.
bretjaquish
Level 3
Level 3
It might show in your device logs also.
