WHY DIDN'T MQC POLICING WORK IN 6509 ?
I was applying policing command to an input policy in my 6509 switch and get the following message in bold. I could do the same thing in my c3560 switch. can someone tell me why? I attached "show ver, and show module".  Eventually I need to apply policing command to my production 6513 switch.
I also tried police cir and police rate and got the same message. Any input will be appreciated.
thanks, Alison
Lab6509(config)#policy-map QOS-LAN
Lab6509(config-pmap)#class LOWPRIORITY
Lab6509(config-pmap-c)#POLICe 2000000
Addition made to policymap QOS-LAN and class LOWPRIORITY is not valid, command is rejected
Lab6509(config-pmap-c)#police  cir 2000000
Lab6509(config-pmap-c)#police rate
Lab6509(config-pmap-c)#police rate 2000000?
WORD
Lab6509(config-pmap-c)#police rate 2000000 ?
  bps             Treat 'rate' value in bits-per-second
  burst           Specify 'burst' parameter
  conform-action  action when rate is less than conform burst
  peak-rate       Specify peak rate or PCR for single-level ATM 4.0 policer policies
  <cr>
Lab6509#sh ver
Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICES-M), Version 15.1(2)SY, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Wed 04-Sep-13 13:05 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
 Lab6509 uptime is 6 weeks, 4 days, 19 hours, 4 minutes
Uptime for this control processor is 6 weeks, 4 days, 19 hours, 0 minutes
System returned to ROM by  power cycle at 08:30:10 PDT Thu Oct 17 2013 (SP by power on)
System restarted at 13:40:08 PDT Wed Jun 18 2014
System image file is "disk0:s72033-ipservices-mz.151-2.SY.bin"
Last reload reason: abort at PC 0x425EAE74
cisco WS-C6509 (R7000) processor (revision 3.0) with 458720K/65536K bytes of memory.
Processor board ID TBM06243664
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
11 Virtual Ethernet interfaces
192 FastEthernet interfaces
20 Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Configuration register is 0x2002
Lab6509#sh modeul
Lab6509#sh modul
Lab6509#sh module
Mod Ports Card Type                              Model              Serial No.
  1   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAL06220EUY
  2   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAL06211171
  3   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAL06220EUB
  4   48  48 port 10/100 mb RJ45                 WS-X6348-RJ-45     SAL0538BTT2
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE     SAL094027BH
  6    2  Supervisor Engine 720 (Hot)            WS-SUP720-BASE     SAL09475LE8
  9   16  16 port 1000mb GBIC ethernet           WS-X6416-GBIC      SAL06200UTZ
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0009.1278.0780 to 0009.1278.07af   6.1   5.4(2)       15.1(2)SY    Ok
  2  0009.1278.01b0 to 0009.1278.01df   6.1   5.4(2)       15.1(2)SY    Ok
  3  0009.1278.0e10 to 0009.1278.0e3f   6.1   5.4(2)       15.1(2)SY    Ok
  4  0005.9a8e.6d60 to 0005.9a8e.6d8f   5.3   5.4(2)       15.1(2)SY    Ok
  5  0013.7f0d.a3cc to 0013.7f0d.a3cf   3.3   8.1(3)       15.1(2)SY    Ok
  6  0014.a97e.1870 to 0014.a97e.1873   3.3   8.1(3)       15.1(2)SY    Ok
  9  0009.1266.6cf0 to 0009.1266.6cff   2.2   5.4(2)       15.1(2)SY    Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Inline Power Module         WS-F6K-VPWR                     1.0    Ok
  2  Inline Power Module         WS-F6K-VPWR                     1.0    Ok
  3  Inline Power Module         WS-F6K-VPWR                     1.0    Ok
  5  Policy Feature Card 3       WS-F6K-PFC3A       SAL09391MNS  2.5    Ok
  5  MSFC3 Daughterboard         WS-SUP720          SAL094027HG  2.5    Ok
  6  Policy Feature Card 3       WS-F6K-PFC3A       SAL094650W8  2.5    Ok
  6  MSFC3 Daughterboard         WS-SUP720          SAL094652GV  2.5    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
  9  Pass
  • LAN Switching and Routing
Everyone's tags (1)
1 REPLY
Please refer below explanation
http://www.cisco.com/c/en/us/support/docs/switches/catalyst-6500-series-switches/71600-tsqos-6k.html#topic11
QoS-ERROR: Addition/Modification made to policymap [chars] and class [chars] is not valid, command is rejected
QoS-ERROR: Addition/Modification made to policymap vtc-map and class voice-video is
This error message indicates that the actions defined in the mentioned class is not allowed in Cisco Catalyst 6500 series switches. There are some restrictions during the configuration of policy map class actions.
-- Pls dont forget to rate helpful posts --
Akash
  • You cannot do all three of these in a policy map class:
    • Mark traffic with the set commands
    • Configure the trust state
    • Configure policing
    You can only either mark traffic with the set commands.
    OR
    Configure the trust state and/or configure policing.
  • For hardware-switched traffic, PFC QoS does not support the bandwidthpriorityqueue-limit, or random-detect policy map class commands. You can configure these commands because they can be used for software-switched traffic.
  • PFC QoS does not support the set qos-group policy map class commands.
60
