Community Member
why i cannot use MQC on Catatlyst 3750 or 3560 !!!!???
it's just a common qos configuration but it doesn't work, please see the detail below.
(but i use the same configuration on 2811,
it works well)
mls qos
class-map match-all IN_NGN_Mgt
match access-group name IN_NGN_Mgt
class-map match-all NGNSig_PSTN
match access-group name NGNSig_PSTN
policy-map test
policy-map mark-dscp
class NGNSig_PSTN
set dscp ef
class IN_NGN_Mgt
set dscp af21
class class-default
set dscp default
interface GigabitEthernet1/0/10
switchport access vlan 12
switchport mode access
switchport nonegotiate
service-policy input mark-dscp
speed 100
duplex full
interface Vlan12
ip address 192.168.4.126 255.255.255.128
ip access-list extended IN_NGN_Mgt
permit ip 192.168.6.0 0.0.0.255 any
permit ip 192.168.4.0 0.0.0.127 any
ip access-list extended NGNSig_PSTN
permit ip 192.168.5.0 0.0.0.127 any
permit ip 192.168.4.200 0.0.0.7 any
permit ip 192.168.4.128 0.0.0.15 any
lks_hwngn_02#sh policy-map int g1/0/10
Service-policy input: mark-dscp
Class-map: NGNSig_PSTN (match-all)
0 packets, 0 bytes
offered rate 0 bps, drop rate 0 bps
Match: access-group name NGNSig_PSTN
Class-map: IN_NGN_Mgt (match-all)
0 packets, 0 bytes
Match: access-group name IN_NGN_Mgt
Class-map: class-default (match-any)
0 packets, 0 bytes
Match: any
0 packets, 0 bytes
rate 0 bps
Super Bronze
Re: why i cannot use MQC on Catatlyst 3750 or 3560 !!!!???
A 3560/3750 is a L3 switch, not a router like the 2811. Many of the latter's features are not supported on former.
In this instance, the inbound marking policy might actually work athough the 3560/3750 won't show you the stats with a show policy. You'll need, I recall, to use some variation of, or something like, "show mls qos stats".
In additional to the good information from Joesph, although the interface command appears in the command line, it is in fact not supported.
Take a look at the 'show policy-map' with the command guide:-
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750/software/release/12.2_44_se/command/reference/cli2.html#wp1948343
The command 'show mls qos interface statistics' will indicate both incoming and outgoing statistics for both CoS and DSCP.
Hope this helps.
Allan.
Pls rate helpful posts.
Community Member
Thank you so much for your reply.
I just wanna tell you that it's worked for vlan-base.
Anyway for MQC, there's nothing marked (af21).
Please see below for "show mls qos int stat"
dscp: incoming
0 - 4 : 19988966 0 0 0 0
5 - 9 : 0 1 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 30 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
dscp: outgoing
0 - 4 : 1324636 0 0 0 0
5 - 9 : 0 0 0 0 0
10 - 14 : 0 0 0 0 0
15 - 19 : 0 0 0 0 0
20 - 24 : 0 0 0 0 0
25 - 29 : 0 0 0 0 0
30 - 34 : 0 0 0 0 0
35 - 39 : 0 0 0 0 0
40 - 44 : 0 0 0 0 0
45 - 49 : 0 0 0 0 0
50 - 54 : 0 0 0 0 0
55 - 59 : 0 0 0 0 0
60 - 64 : 0 0 0 0
cos: incoming
0 - 4 : 19996349 0 0 0 0
5 - 7 : 0 0 0
cos: outgoing
0 - 4 : 1324797 0 0 0 0
5 - 7 : 0 0 89
Policer: Inprofile: 0 OutofProfile: 0
141
