Why isn't my HSRP preemption working?
Venison Mogambi
I've been playing around with a very basic HSRP Preempt configuration and I can't get my Standby switch to take over as the active. Here's the scenario:
Switch 1 is the Active, with Priority set at 105.
Switch 2 is the Standby, with Priority left at default (100). Preempt is configured on Switch 2.
When both switches are up and operational, the Standby group looks good. For example, when I do a show standby on Switch 1 I get the following:
Vlan100 - Group 1
  State is Active
    2 state changes, last state change 00:25:51
  Virtual IP address is 10.10.10.3
  Active virtual MAC address is 0000.0c07.ac01
    Local virtual MAC address is 0000.0c07.ac01 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 0.704 secs
  Preemption disabled
  Active router is local
  Standby router is 10.10.10.2, priority 100 (expires in 10.512 sec)
  Priority 105 (configured 105)
  Group name is "hsrp-Vl100-1" (default)
So if I power down Switch 1, the HSRP and the preemption that I configured on Switch 2 should cause it to take over as the Active switch, correct? But when I power down Switch 2 and then do a show standby on Switch 2, I only get the following:
Switch2#show standby
Vlan100 - Group 1
  State is Init (interface down)
    6 state changes, last state change 00:00:26
  Active virtual MAC address is unknown
  Preemption enabled
  Active router is unknown
  Standby router is unknown
  Priority 100 (default 100)
Am I doing something wrong? Why does Switch 2 not take over as the Active switch? For your reference, here are the HSRP configs on both Switch 1 and Switch 2:
Switch 1:
interface Vlan100
 ip address 10.10.10.1 255.255.255.0
 standby 1 ip 10.10.10.3
 standby 1 priority 105
Switch 2:
interface Vlan100
 ip address 10.10.10.2 255.255.255.0
 no ip route-cache
 standby 1 preempt
Any insight is appreciated, thanks.
glen.grant
   Do you have at least one interface in vlan 100 that is up and active on switch 2 when you power off switch one ?  The SVI will not stay up unless you do.
glen.grant
Yup, that did it! I should have thought of that, really.
Thanks very much for the feedback.
Hello
How are the switches connected to either other - access port or trunked?
res
Paul
Kind Regards
Paul
