05-23-2012 09:08 AM - edited 03-07-2019 06:51 AM
Hi all,
I was finding out which device is connected to switch port.
I did this command to find mac address
sh mac address-table int gigabitEthernet 2/23
Multicast Entries
vlan mac address type ports
225 ffff.ffff.ffff system Gi2/1,Gi2/2,Gi2/4,Gi2/5,Gi2/6,Gi2/7,Gi2/8
Gi2/9,Gi2/10,Gi2/11,Gi2/12,Gi2/13,Gi2/14
Gi4/39,Gi4/43,Gi4/48,Po25
625 ffff.ffff.ffff system Gi2/1,Gi2/2,Gi2/5,Gi2/6,Gi2/7,Gi2/8,Gi2/9
Gi2/10,Gi2/11,Gi2/12,Gi2/14,Gi2/15,Gi2/16
Gi4/48,Po25
seems ffff is all broadcast address .
Need to know why this is not showing mac address thanks
MAhesh
Solved! Go to Solution.
05-23-2012 03:00 PM
Most of the time, the MAC address does not show up when the clients have logged off. This is very common nowadays with PCs. Another is when a server's dual NIC isn't configured properly for "teaming".
If you don't know the exact IP address, there's an old trick (not foolproof) you could try. IF you know what VLAN the NIC is in, ping the broadcast IP address from the switch. Sometimes it just may work.
05-23-2012 03:51 PM
Hi leolaohoo,
The port is up up.
I know port is in voice and data vlan.
How can i find the broadcast IP for each vlan?
MAhesh
05-23-2012 04:59 PM
Please post the output to the command: sh interface VLAN .
05-23-2012 05:32 PM
Hi leolaohoo,
Here is info
Internet address is 192.168.20.1/24
MAhesh
05-23-2012 06:37 PM
Your broadcast IP address is 192.168.20.255. Ping that.
05-23-2012 08:36 PM
Hi leolaohoo,
If i ping to broadcast IP my concern is that will this increase cpu spike as it is production device?
When i ping this IP it will send ping to all devices connected to this Vlan right?
also to other nei switches which are in data vlan right?
Mahesh
05-23-2012 08:43 PM
Ping won't kill CPU.
If your switches are all in the same subnet, yes.
05-24-2012 07:49 AM
Hi Leolaohoo,
My bad the switch function as layer 2 it has static default route to core device.
Data vlan is on core switch.
IT has runk connection to core switch.
MAhesh
