05-23-2012 01:09 AM - edited 03-07-2019 06:51 AM
I am a newbie here. We have two catalyst 3560X 24T-S switches connected on two separate LANs (both the networks are redundant to each other).
The last port of the switches are connected together? Please tell me what for it is done?
Solved! Go to Solution.
05-23-2012 03:01 AM
I think this is what you are looking for:
Please don't forget to rate our useful posts. Thanks.
05-23-2012 11:29 PM
Hi Gunda,
The command to check the interface configuration is "show run int
Kind Regards,
Ivan
**Please grade this post if you find it useful.
05-24-2012 06:24 AM
Hi Gunda,
Trunks carry the traffic of multiple VLANs over a single link and allow you to extend VLANs across an entire network.
For example, if you have 2 different connections from switches to WAN or other LANs, in case WAN connection on switch A fails, the reachability in vlan to WAN will be available through WAN connection on switch B. Traffic from switch A will be passing to switch B via trunk link.
The link shared by leolaohoo is quite good for understanding how a trunk works, I suggest to check it if you have configuration/
Also see this book:
http://www.ciscopress.com/articles/article.asp?p=29803&seqNum=3
Kind Regards,
Ivan
05-30-2012 08:14 AM
HI Ramesh,
My bad, sorry for mistake - I was looking at another post while typing and messed up the names :$
Stack ports is a separate entity. Uplink ports are the port on network ports. They are called so because network modules are often called "uplink network modules" and used for connecting to higher level of the network (e.g. to core or aggregation switch).
Kind Regards,
Ivan
05-23-2012 01:58 AM
Hi Gunda,
Could you send the ports configuration from both switches?
Since you mentioned redundancy, could it be that this port connection ensures reachbility through another switch, should the local network connectivity fail?
Kind Regards,
Ivan
05-23-2012 03:01 AM
05-24-2012 12:19 AM
Hi leolaohoo
thanks for your reply, I think you are right, it is something to do with trunking. I am yet to go thru the link you supplied. In short what for trunking is applied, please tell me.
05-23-2012 11:06 PM
Hi Ivan
thanks for your reply. Please tell me how to obtain the ports configuration, so that I can post the details?
Secondly what I mean by the networks redundant to each other in my original post is, on the hosts connected to these switches both the ports are teamed via Intel Motherboard configuration.
05-23-2012 11:29 PM
Hi Gunda,
Kind Regards,
Ivan
05-24-2012 12:16 AM
Hi Ivan
the output of the command show run int Gi0/24 is
interface GigabitEthernet 0/8
switchport mode trunk
srr-queue bandwidth share 1 30 35 5
queue set 2
priority-queue out
mls qos trust cos
macro description cisco-switch
auto qos trust
spanning-tree link type point-to-point
end
The same configuration is appearing on Gi0/8.
I happened to check the switch thru CNA, it shows under Switching / VLANS
Port no. Admin mode Operational mode VLANS
8 802.1Q Trunk 802.1Q Trunk ALL
24 802.1Q Trunk 802.1Q Trunk ALL
All other Dynamic Auto Static Access 1
ports
05-24-2012 12:33 AM
Hi Gunda,
This confirms the suggestion from before, the port is a trunk between switches as leolaohoo suggested.
You already confirmed the same via CNA - Operational mode is a trunk for all vlans.
Kind Regards,
Ivan
05-24-2012 12:37 AM
Hi Ivan
thnaks, can you please tell me what is the requirement/advantage of doing this?
05-24-2012 06:24 AM
Hi Gunda,
Also see this book:
Kind Regards,
Ivan
05-28-2012 03:18 AM
Ivan Shirshin wrote:
Hi Gunda,
Also see this book:
Kind Regards,
Ivan
Hi Ivan
sorry, I was away and could not see your reply immediately.
thanks a lot for your answer, that was a short & sweet reply and to the point. I will definitely go thru these links.
sorry to trouble you with some more questions:
1. The trunking on 24 th port is understandable , then why on 8th port also it is deifned?
2. Are the network modules used for increasing the reach of the LAN?
G.Ramesh.
05-28-2012 05:50 AM
Hi Ahmed,
Glad it was helpful!
In regards to your questions:
1. I understand from your previous explanation that this pair of switches are connected only on the last port 24.
That means the port 8 connects to another node and port 8 is a means to extend your vlans over 3rd switch.
2. When you install a network services module in a Catalyst 3560-X or 3750-X switch, you can configure the 1-Gigabit and 10-Gigabit Ethernet uplink ports for the same features as any other ports in the switch. So it also could be configured as trunk.
Kind Regards,
Ivan
05-30-2012 07:55 AM
Hi Ahmed,
No it is Ramesh not Ahmed
2. When you install a network services module in a Catalyst 3560-X or 3750-X switch, you can configure the 1-Gigabit and 10-Gigabit Ethernet uplink ports for the same features as any other ports in the switch. So it also could be configured as trunk.Uplink ports means for stacking or for extending LAN?
Kind Regards,
Ivan
Ramesh
05-30-2012 08:14 AM
HI Ramesh,
Kind Regards,
Ivan
05-30-2012 09:38 AM
HI Ramesh,
It's ok.Stack ports is a separate entity. Uplink ports are the port on network ports. They are called so because network modules are often called "uplink network modules" and used for connecting to higher level of the network (e.g. to core or aggregation switch).
Thanks for the infoKind Regards,
Ivan
Ramesh
