10-20-2006 03:15 PM - edited 03-05-2019 12:22 PM
Hi, can you help me on this ?
I am following the configuration from the link below.
From workstation1, I can ping the default the router successfully. However, I can't ping anything from workstation2. My goal is to ping from workstation1 to workstation2 and vice-versa. Can you please suggest how I can troubleshoot this ? Diagram and router, switch config is attached.
http://www.cisco.com/en/US/tech/tk389/tk390/technologies_configuration_example09186a00800949fd.shtml
10-22-2006 07:15 PM
Ah, sorry, I forgot to tell you that I tried before 'show interface fa0/1 trunk' and that was a not valid command.
Switch#show int fa0/1 switchport
Switchport: Enabled
Administrative mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 1 (default)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1,2,4
Pruning VLANs Enabled: 2-1001
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
Switch#show interface fa0/1 trunk
% Invalid input detected at '^' marker.
Switch#
: FAB0501M2K0
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5.2)XU, MAINTENANCE IN
TERIM SOFTWARE
Copyright (c) 1986-2000 by cisco Systems, Inc.
Compiled Mon 17-Jul-00 17:35 by ayounes
Image text-base: 0x00003000, data-base: 0x00301F3C
ROM: Bootstrap program is C2900XL boot loader
Switch uptime is 2 hours, 14 minutes
System image file is "flash:c2900XL-c3h2s-mz-120.5.2-XU.bin"
cisco WS-C2912-XL (PowerPC403GA) processor (revision 0x11) with 8192K/1024K byte
s of memory.
Processor board ID FAB0501M2K0, with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
12 FastEthernet/IEEE 802.3 interface(s)
10-22-2006 07:32 PM
I think I see the problem; add the following config to your switch and let us know if it helps.
interface VLAN2
ip address 10.10.11.2 255.255.255.0
no shutdown
10-22-2006 08:34 PM
I've done as per your recommendation, but no improvement. I noticed that 'show int vlan 2' continues to display the interface as down, in spite of my 'no shutdown' commands. Any ideas ?
show run
Building configuration...
Current configuration:
version 12.0
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
ip subnet-zero
interface FastEthernet0/1
--More-- switchport mode trunk
interface FastEthernet0/2
switchport access vlan 2
spanning-tree portfast
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
--More-- interface FastEthernet0/11
interface FastEthernet0/12
interface VLAN1
ip address 10.10.10.2 255.255.255.0
no ip directed-broadcast
no ip route-cache
interface VLAN2
no ip route-cache
shutdown
ip default-gateway 10.10.10.1
line con 0
transport input none
stopbits 1
line vty 0 4
login
line vty 5 15
--More-- login
end
Switch#
User Access Verification
Password:
RouterB>en
Password:
RouterB#show run vlan
Virtual LAN ID: 1 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: Ethernet0/0.1
This is configured as native Vlan for the following interface(s) :
Ethernet0/0
Protocols Configured: Address: Received: Transmitted:
IP 10.10.10.1 0 0
Virtual LAN ID: 2 (IEEE 802.1Q Encapsulation)
vLAN Trunk Interface: Ethernet0/0.2
IP 10.10.11.1 48 9
RouterB#
10-22-2006 09:57 PM
What kind of router you are working with.
Because it seems like you have 10mbps interfaces and there is no way you can do intervlan routing on 10 mbps interfaces.min speed is 100 mbps...
10-22-2006 10:24 PM
Thanks for your help !
It is a C2610, ethernet (10Mb/s) interface.
I heard reports from multiple people saying that they were able to make this work even in a 10Mb/s interface(?). Confusing. Well, I will see if I order one fastethernet interface and put an end to this for good. Hold on please. I will be back as soon as I receive my fastethernet interface.
10-23-2006 01:59 AM
Hi, I think the issue is with the Native statement. Firstly trunking using dot1q definetly works on 10mb interfaces. When you trunk between a router & switch the sub-interfaces are always tagged on the router. If you add an IP address on the main interface then this will be untagged and will be considered to be Native VLAN. I know there is the option of adding the Native keyword under the encapsulation command but I could not get this to work. If you want to use the Native/untagged VLAN try configuing an address on the main interface.
So in your example configure Vlan1 IP address on the main interface on the router.
10-23-2006 06:41 AM
news2010a,
interface VLAN2 on the switch is showing down because you haven't issued "no shutdown" on it :) Do that and see what happens.
Mark;
I have seen the native VLAN work plenty of times on subinterfaces. Just for common courtesty for future engineers, it is bad practice to use the main interface along with sub-interfaces, however it will work.
Everyone else;
It IS possible to use trunking on regular ethernet interfaces!! I have used this particular router with a cat3550 and used dot1q trunking in the same fashion!
10-23-2006 07:54 AM
Adam, as I said in my previous post, I did issue the command 'no shutdown' - multiple times actually. However, VLAN2 continues down, down.
Any idea what could be causing this to remain down in spite of my 'no shutdown' commands ?
10-23-2006 08:52 AM
Everything looks fine, I'm stumped
10-23-2006 12:17 PM
I already restarted the switch, I swaped workstation1 with workstation2 ports, but same behavior. No improvement.
10-23-2006 12:39 PM
2912XL is a pure L2 beast and support only one management vlan configured with ip address, that's why your vlan2 stays in shutdown mode. remove static routes from workstation and configure them with respective default gateways. disable pruning for vlan 2 on the switch.
10-23-2006 02:46 PM
As another poster indicated your int vlan 2 is shutdown because you can only have 1 layer 3 SVI up at any one time on layer 2 switch because all that address does is manage the switch , has no effect on any routing so you can either have a vlan 1 address manage the switch or have vlan 2 address manage the switch in which case you will have to do a shutdown on vlan 1 and a no shut on vlan 2 . Also you would have to change your default gateway to the layer3 routing devices address for the vlan 2 subnet . If you need to have both networks on the switch then of course you have to get the trunking working between the 2900 and the router .
10-23-2006 04:49 PM
I tried that. I did shutdown on vlan1, I did 'no shut' on vlan2. Then vlan2 went up. I also removed the static entries from the workstations and used the default-gateway instead. I turned off vtp pruning on the swtich.
No improvement.
10-24-2006 12:32 AM
Hi Adam,
Can you provide a link which states it's bad practice to use the main interface? In addition I have lab tested this form of trunking several times and on the IOS versions I have used I could only get the Native VLAN working on the main interface. The Native command did not work on the IOS version I'm using. It may be IOS dependant bet perhaps you can provide versions of IOS where you have this working?
