why traceroute lost ,ping is ok
topnewinfo
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet1/1     10.0.60.5       YES NVRAM  up                    up
GigabitEthernet1/2     10.0.60.29      YES manual up                    up
GigabitEthernet1/3     unassigned      YES NVRAM  down                  down
GigabitEthernet1/4     unassigned      YES manual down                  down
GigabitEthernet1/5                            YES NVRAM  down                  down
GigabitEthernet1/6                            YES manual administratively down down
GigabitEthernet1/7     10.0.60.17      YES manual up                    up
GigabitEthernet1/8     unassigned      YES manual up                    up
JT-a#traceroute 10.0.60.6
Tracing the route to 10.0.60.6
  1 10.0.60.6 0 msec *  0 msec
JT-a#traceroute 10.0.60.18
Tracing the route to 10.0.60.18
  1 10.0.60.18 4 msec *  4 msec
JT-a#tr 10.0.60.30
Tracing the route to 10.0.60.30
  1 10.0.60.30 0 msec *  0 msec
JT-a#ping 10.0.60.30
Sending 5, 100-byte ICMP Echos to 10.0.60.30, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/4 ms
JT-a#ping 10.0.60.18
Sending 5, 100-byte ICMP Echos to 10.0.60.18, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
JT-a#ping 10.0.60.6
Sending 5, 100-byte ICMP Echos to 10.0.60.6, timeout is 2 seconds:
Steve Fuller
Level 9
Level 9
Losing a single probe at some hops in the traceroute output is typically due rate limiting running on the router that is responding to the probe, and is not a cause or concern.
Take a read of the Packet Life blog, Traceroute timeouts for further details of the cause.
Steve Fuller
Level 9
Level 9
hi steve.
Thanks. After executing the no ip icmp rate-limit unreachable command, It's ok. thank u.
but, why don't executing the  sh ip icmp  command?
4506-E-2#sh ip icmp
% Invalid input detected at '^' marker.
4506-E-2#sh ip i?
igmp  interface  irdp
