Community Member
Why vlan1 continues 'down', I can't ping it?
On my local 3560 switch, I defined vlan1 as shown below. Then I see that in spite of my 'no shut' command', line protocol remains down. Why is like that? Of course from there I can't ping it. What do I need to do in order to make this vlan turns to 'line protocol up'?
#show int vlan1
Vlan1 is up, line protocol is down
3560new#show run
Building configuration...
Current configuration : 2134 bytes
version 12.1
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname 3560new
ip subnet-zero
ip routing
vtp mode transparent
spanning-tree mode pvst
no spanning-tree optimize bpdu transmission
interface Loopback0
ip address 192.169.202.16 255.255.255.0
interface FastEthernet0/1
no ip address
no mdix auto
interface FastEthernet0/2
no ip address
no mdix auto
interface FastEthernet0/3
no ip address
no mdix auto
interface FastEthernet0/4
no ip address
no mdix auto
interface FastEthernet0/5
no ip address
no mdix auto
interface FastEthernet0/6
no ip address
no mdix auto
interface FastEthernet0/7
no ip address
no mdix auto
interface FastEthernet0/8
no ip address
no mdix auto
interface FastEthernet0/9
no ip address
no mdix auto
interface FastEthernet0/10
no ip address
no mdix auto
interface FastEthernet0/11
no ip address
no mdix auto
interface FastEthernet0/12
no ip address
no mdix auto
interface FastEthernet0/13
no ip address
no mdix auto
interface FastEthernet0/14
no ip address
no mdix auto
interface FastEthernet0/15
no ip address
no mdix auto
interface FastEthernet0/16
no ip address
no mdix auto
interface FastEthernet0/17
no ip address
no mdix auto
interface FastEthernet0/18
no ip address
no mdix auto
interface FastEthernet0/19
no ip address
no mdix auto
interface FastEthernet0/20
no ip address
no mdix auto
interface FastEthernet0/21
no ip address
no mdix auto
interface FastEthernet0/22
no ip address
no mdix auto
interface FastEthernet0/23
no switchport
ip address 150.x.x.251 255.255.255.248
duplex full
speed 100
no mdix auto
fair-queue
interface FastEthernet0/24
no switchport
no ip address
no mdix auto
interface GigabitEthernet0/1
no ip address
interface GigabitEthernet0/2
no ip address
interface Vlan1
ip address 150.x.x.101 255.255.255.248
interface Vlan2
ip address 150.x.x.137 255.255.255.248
shutdown
ip classless
ip http server
line con 0
line vty 5 15
end
#show int vlan1
1 ACCEPTED SOLUTION
bjw Silver
Silver
Re: Why vlan1 continues 'down', I can't ping it?
I believe you need at least 1 interface on VLAN 1 UP/UP - Connected - for the VLAN to show up/up
bjw Silver
Silver
Purple
You need at least one active port in the vlan in order to bring up the SVI .
Hall of Fame Super Gold
Marlon
Is there at least one interface with something plugged into it which is in VLAN 1? There needs to be an up/up interface within the VLAN for the VLAN to be in an up state.
Rick
Community Member
That makes sense. Since I made the port fa0/23 and fa0/24 as 'no switchport', then those are plugged but they are no longer part of vlan1, hence this behavior. I will plug something in there later. Thanks!
342
