WIC 2T Inter Connectivity Problem
aqusingh7
Basically I am facing a problem where I have this setup:-
                          DTE      HQ     DCE  ( s0/1/1  "admin down" 192.168.9.161 )
                          ok    /             \    x
        DCE     Branch1              Branch2    DTE   ( s0/1 "down" 192.168.9.190 )
The connection btwn HQ & Branch2 has failed !!!
Branch 2 & HQ has all the clocking64k(DCE only), bandwidth56k, no shutdown, ip addresses (subnets)  set properly.
These are WIC 2T (smart serial) connections.
Br 2  &  HQ  flash up on/off   during boot. But lights fail to show after router initialisation complete.
I have checked all WIC 2T cards & replaced with new ones. Used new cables too.
HQ is a cisco 1841 advanced IP services security Router. (SDM)
Branch 1 & 2 are old cisco 2620 routers.
I will give you further info in the attachments. Such as Admin Down/ Down  / sh ip int brief / sh run/ sh interface
If you can help. I thought it was how the bandwidth/ clockrate cmd was worded/ written on each different router.
Any insight is invaluable:   baljitsingh@talktalk.net
How many WIC2T cards are allowed on a 1841 router? I have tried 2 WIC 2T cards i am prsently with & 1 WIC2T card.
Reza Sharifi
On the HQ router s0/1/1 is shut can you do a no sh and try again?
also, what is the output of sh cont int s0/0/1?
Reza Sharifi
Thanks so much. That worked ! Wow ! I am so thankful.
Also add me on as a contact/ friend on LinkedIn   "Baljit Singh"  or   "Baljit Singh Passan"
email: baljitsingh@talktalk.net
Appreciate your insight.
Message was edited by: Baljit Singh Passan
