09-23-2008 09:08 AM - edited 03-06-2019 01:32 AM
Is the WIC-4ESW compatible with the 2651XM? I've seen a document that showed it was, and so I ordered the WIC card. Now all I'm seeing is that it is compatible with the 1700. Is this true??
09-23-2008 11:15 AM
Corey
I have looked in several places and do not find an authoritative list of what is supported for the 2651XM. But every reference that I find for the WIC-4ESW talks about 1700 and not 2651XM.
If you have the WIC then what happens if you put it into the router? My guess is that it will not be recognized.
Rick
09-23-2008 11:28 AM
Corey
AFAIK this card is only supported in the 1700 router. The following document suggests this is the case
Jon
