WIC card has an unknown ID of 0x
WGUNTERCISCO
Help - Installed ethernet wic, can't access or configure. Please advice
11 Replies 11
Mark Yeates
Level 7
Level 7
What router are you using? Also what is the WIC you are trying use and what IOS version are you running?
Mark
1720 router with 1enet wic,
IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(7c), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Fri 10-May-02 19:06 by pwade
Image text-base: 0x800080E0, data-base: 0x806F2D18
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
any help would be great!
It looks like you will need an IOS upgrade for this card to work.
The Cisco WIC-1ENET card requires Cisco IOS Release 12.2(2)XJ or later if the card is installed in any WIC slot other than slot 0 or if more than one card is installed.
The card can be used with Cisco IOS Release 12.2(4)T, but the card must be installed in slot 0 and only one Cisco WIC-1ENET card can be installed in the router.
HTH,
Mark
The card is in slot 0 and it is the only WIC installed. does 12.2(7) support this.
It requires 12.2(7)T. That is a completely different release than what you currently have.
Mark
How can I get a copy of the IOS. The cisco website will not let me download?
You will need a valid SMARTnet contract on the router to be able to download software updates for your router from Cisco.
Mark
Will this version work?
System Bootstrap, Version 12.2(7r)XM2, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 2003 by cisco Systems, Inc.
C1700 platform with 65536 Kbytes of main memory
That seems to not be an IOS version, but bootstrap for the router itself.
Cisco IOS Software, C1700 Software (C1700-IPBASE-M), Version 12.4(5), RELEASE SO
FTWARE (fc3)
How about this one?
I'm not so sure that is for a 1720. You could give it a try but remember that routers have minimum flash and RAM requirements. It very well could work. Here are instructions on how to upgrade the IOS.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a00801fc986.shtml#topic1
Mark
