Wic T1-DSU in a 1760
Can someone please tell me what version and feature sets of IOS is needed to run a WIC-1DSU T1 in a 1760 router? Thanks
Hall of Fame Super Bronze
Re: Wic T1-DSU in a 1760
Edison,
The IOS release recommended in the link you gave me is 12.2(15)ZL PCBU which is old and deferred. I would have to believe that there is a newer 12.3 version of software to work with the Wic T1 DSU. What feature set is required for this DSU? Please advise
That's the 'minimum' supported release, you can run a later release and should work w/o problems.
Any feature set will work.
HTH,
__
Edison.
122
