06-19-2014 12:43 AM - edited 03-07-2019 07:46 PM
Hi Guys,
I have ran in a wierd situation where my HSRP active router changed its state from ACTIVE to Speak with out any high priority box being introduced.
Logs
Apr 30 16:29:57.384 GMT: %HSRP-5-STATECHANGE: Vlan191 Grp 0 state Active -> Speak
Apr 30 16:29:57.388 GMT: %HSRP-4-DIFFVIP1: Vlan191 Grp 0 active routers virtual IP address 165.42.36.1 is different to the locally configured address 165.42.35.1
Apr 30 16:29:57.392 GMT: %HSRP-5-STATECHANGE: Vlan200 Grp 0 state Standby -> Listen
Apr 30 16:29:57.444 GMT: %HSRP-5-STATECHANGE: Vlan191 Grp 0 state Speak -> Standby
Apr 30 16:30:01.004 GMT: %HSRP-5-STATECHANGE: Vlan200 Grp 0 state Speak -> Standby
Apr 30 16:30:01.300 GMT: %HSRP-5-STATECHANGE: Vlan191 Grp 0 state Standby -> Active
Apr 30 19:47:47.047 GMT: %CLEAR-5-COUNTERS: Clear counter on all interfaces by psauto on vty1 (171.174.12.145)
Apr 30 20:15:48.678 GMT: %SYS-4-SNMP_WRITENET: SNMP WriteNet request. Writing current configuration to 171.174.12.135
SW01#
.Apr 30 16:29:57.562 GMT: %HSRP-4-DIFFVIP1: Vlan191 Grp 0 active routers virtual IP address 165.42.36.1 is different to the locally configured address 165.42.35.1
.Apr 30 16:29:57.562 GMT: %HSRP-5-STATECHANGE: Vlan191 Grp 0 state Standby -> Listen
.Apr 30 16:30:07.941 GMT: %HSRP-5-STATECHANGE: Vlan191 Grp 0 state Speak -> Standby
.Apr 30 19:47:47.005 GMT: %CLEAR-5-COUNTERS: Clear counter on all interfaces by psauto on vty0 (171.174.12.145)
.Apr 30 20:15:57.259 GMT: %SYS-4-SNMP_WRITENET: SNMP WriteNet request. Writing current configuration to 171.174.12.135
SW02#
SW01#sh stand br | i 191|200
Vl191 0 105 P Active local 165.42.35.3 165.42.35.1
Vl200 0 100 Standby 165.42.36.3 local 165.42.36.1
SW01#
SW02#sh stand br | i 191|200
Vl191 0 100 Standby 165.42.35.2 local 165.42.35.1
Vl200 0 105 P Active local 165.42.36.2 165.42.36.1
SW02#
SW01 | SW02 | |
SW01#sh stand vlan 200 | SW02#sh stand vlan 200 | |
Vlan200 - Group 0 | Vlan200 - Group 0 | |
State is Standby | State is Active | |
21 state changes, last state change 10:36:21 | 9 state changes, last state change 6d12h | |
Virtual IP address is 165.42.36.1 | Virtual IP address is 165.42.36.1 | |
Active virtual MAC address is 0000.0c07.ac00 | Active virtual MAC address is 0000.0c07.ac00 | |
Local virtual MAC address is 0000.0c07.ac00 (v1 default) | Local virtual MAC address is 0000.0c07.ac00 (v1 default) | |
Hello time 1 sec, hold time 3 sec | Hello time 1 sec, hold time 3 sec | |
Next hello sent in 0.048 secs | Next hello sent in 0.496 secs | |
Authentication text "baronet2" | Authentication text "baronet2" | |
Preemption disabled | Preemption enabled | |
Active router is 165.42.36.3, priority 105 (expires in 2.736 sec) | Active router is local | |
Standby router is local | Standby router is 165.42.36.2, priority 100 (expires in 3.520 sec) | |
Priority 100 (default 100) | Priority 105 (configured 105) | |
IP redundancy name is "hsrp-Vl200-0" (default) | IP redundancy name is "hsrp-Vl200-0" (default) | |
SW01#sh stand vlan 191 | SW02#sh stand vlan 191 | |
Vlan191 - Group 0 | Vlan191 - Group 0 | |
State is Active | State is Standby | |
14 state changes, last state change 10:36:25 | 15 state changes, last state change 10:37:54 | |
Virtual IP address is 165.42.35.1 | Virtual IP address is 165.42.35.1 | |
Next hello sent in 0.048 secs | Next hello sent in 0.880 secs | |
Preemption enabled | Preemption disabled | |
Active router is local | Active router is 165.42.35.2, priority 105 (expires in 3.072 sec) | |
Standby router is 165.42.35.3, priority 100 (expires in 2.864 sec) | Standby router is local | |
Priority 105 (configured 105) | Priority 100 (default 100) | |
IP redundancy name is "hsrp-Vl191-0" (default) | IP redundancy name is "hsrp-Vl191-0" (default) |
Can some one explain why did the Active Switch SW01 for VLAN191 went from active to speak mode while there was no change done in topology and all remains same.
06-19-2014 09:39 AM
Do you have tracking enabled under HSRP configuration for those interfaces? (IIf enabled, it may show in ' Sh stand vlan xxx' but I'm not sure). One possibility is if tracking interface not available the Active router may experience this behavior.
Thx
MS
