wildcard mask
mahmoodmkl
Level 7
Level 7
Hi Guys
i have some confusion understanding the wildcard masks.
For eg:we have below networks which i want to calculate the wildcard mask.
192.168.32.0/24
192.168.33.0/24
192.168.34.0/24
192.168.35.0/24
192.168.36.0/24
192.168.37.0/24
192.168.38.0/24
192.168.39.0/24
now if we summarize these then we get 255.255.248.0
if i want to calculate the wildcard mask then i will inverse the bit i.e
11111000
00000111
now my confusion is i am saying the 5 bits should match in the third octet and the 3 bits dnot care.
My confusion is how we are getting the the mask 0.0.7.255.
Mahmood
5 Replies 5
Joseph W. Doherty
"My confusion is how we are getting the the mask 0.0.7.255. "
You just calculated the 3 octet binary value as 00000111, which is 7 in decimal. The full inversion is:
255.255.248.0
11111111 11111111 11111000 0000000
00000000 00000000 00000111 1111111
0.0.7.255
I understand that we will get this result.
My question is how does the mask 0.0.7.255 covers all the subnet ranges i.e 192.168.32.0 - 192.168.39.0..?
if we summarize the below address we will get the mask as
255.255.248.0.
And if we invserse it how is it covering this range of address.
Sorry for stupid question.
Mahmood
amr.momtaz
Dear Mahmoud,
your problem is with the summerized address itself; it should be 192.168.32.0 /20 (subnet mask of 255.255.240.0) which is going to result in a wildcard mask of 0.0.15.255
Now I am going to tell you how I reached that result. (I am assuming you know a little binary, if not you should work on that first)
in your example, you have the subnets
192.168.32.0 /24
192.168.33.0 /24
192.168.34.0 /24
192.168.39.0 /24
this sequence indeed qualifies for a summarized address because we can notice that the first 16 bits are always the same (192.168.0.0) + if we convert the rest of the subnets to binary, we are going to find that the first 4 bits are always the same.
when doing summerization I always prefer to use this method;
first put all the 8 bits like this
128 64 32 16 8 4 2 1
0 0 0 0 0 0 0 0
then assign the 1 to the bits until you get the network you want to get (in our example 32,33,34...39)
0 0 0 0 0 0 0 0
for 32: 0 0 1 0 0 0 0 0
for 33: 0 0 1 0 0 0 0 1
for 34: 0 0 1 0 0 0 1 0
for 35: 0 0 1 0 0 0 1 1
for 36: 0 0 1 0 0 1 0 0
for 37: 0 0 1 0 0 1 0 1
for 38: 0 0 1 0 0 1 1 0
for 39: 0 0 1 0 1 0 0 1
we notice that the 4 most significant bits (the 4 bits from the left, the ones that are responsible for the 32) doesn't change for all the subnets. so we are going to add 4 bits to the subnet mask that we already have 16 + 4 = 20 (255.255.240.0)
Here is another hint that will help you to get the wildcard mask;
wildcard mask = 255.255.255.255-Subnet Mask
Wildcard Mask (for our example) = 255.255.255.255 - 255.255.240.0 = 0.0.15.255
Hope that solved your problem and made subnetting, route summarization a little more easier.
Sorry you all,
I messed up while converting to binary (Gotta watch out for those simple mistakes that would have catastrophic effects !)
Here is the same topic after the fix
your problem is with the summerized address itself; it should be 192.168.32.0 /20 (subnet mask of 255.255.248.0) which is going to result in a wildcard mask of 0.0.7.255
192.168.32.0 /24
192.168.33.0 /24
192.168.34.0 /24
192.168.39.0 /24
this sequence indeed qualifies for a summarized address because we can notice that the first 16 bits are always the same (192.168.0.0) + if we convert the rest of the subnets to binary, we are going to find that the first 5 bits are always the same.
0 0 0 0 0 0 0 0
0 0 0 0 0 0 0 0
for 39: 0 0 1 0 0 1 1 1
we notice that the 5 most significant bits (the 5 bits from the left, the ones that are responsible for the 32) doesn't change for all the subnets. so we are going to add 5 bits to the subnet mask that we already have 16 + 5 = 21 (255.255.248.0)
Wildcard Mask (for our example) = 255.255.255.255 - 255.255.248.0 = 0.0.7.255
