Will changing VTP mode cause a recalculation
If I change a switch from a VTP server to a VTP client will it cause a spanning tree recalculation?
Re: Will changing VTP mode cause a recalculation
No, it will not.You should be fine with it.VTP mode has nothing to do with STP
HTH,
-amit singh
Nope, it won't. VTP is used just to have consistency of VLAN information across VTP domain.
Thank you, I thought as much, but I need to make a change on a huge core and didn't want to cause havoc. ;-)
151
