10-28-2013 02:32 PM - edited 03-07-2019 04:17 PM
Hi Everyone,
Client has cisco 2801 router connected to cisco 3550 switch and this switch 3550 died.
Switch has no warranty.
They bought new switch ASUS GX-D1241 V3 as replacemet for cisco switch.
THey have DMVPN connection to head office.
I am not physically at this site.
Need to confirm will this switch work with cisco router?
My thinking is no but need to confirm with you experienced people here?
MAhesh
Message was edited by: mahesh parmar
Solved! Go to Solution.
10-28-2013 04:55 PM
Just checked the specification sheet, and I don't see anything being mentioned about 802.1q.
If you are NOT doing any 802.1q Trunking then this should be fine.
10-28-2013 05:07 PM
According to Leo, that switch cannot trunk. Since the router interface is configured as a trunk, this switch will NOT work.
10-28-2013 05:25 PM
will it work now?
My opinion is, no. This switch doesn't understand multiple VLANs. Heck, I'm not even sure if this switch understands anything other than VLAN 1.
10-28-2013 04:55 PM
10-28-2013 04:57 PM
Hi Leo,
Seems router has trunk with switch as router interface config is
erface FastEthernet0/1.250
description ** Data VLAN **
encapsulation dot1Q 250
ip address 192.168.250.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1300
interface FastEthernet0/1.251
description ** Voice VLAN **
encapsulation dot1Q 251
ip address 192.168.251.1 255.255.255.0
ip nat inside
--More-- ip virtual-reassembly
service-policy output output-L3-to-L2
will it work now?
MAhesh
10-28-2013 05:07 PM
10-28-2013 05:25 PM
will it work now?
10-28-2013 10:06 PM
Hi Leo,
Thanks again for timely help.
That switch was not working as it was not configurable.
I will config the cisco switch and will advice the client.
Best regards
MAhesh
10-29-2013 05:49 PM
Thanks Mahesh.
