Community Member
Will 'no switch x provision' cause switch to reload ?
Hi there
I have inherited a switch stack as follows:
Switch#  Role   Mac Address     Priority Version  State
*1       Master 04fe.7f0d.2280     1      0       Ready
2       Member 0000.0000.0000     0      0       Provisioned
3       Member ec44.76e5.7980     1      0       Ready
4       Member 0064.40aa.2200     1      0       Ready
UK01SW47#sh swi stack-p
  Switch #    Port 1       Port 2
    1          Down          Ok
    3           Ok           Ok
    4           Ok          Down
UK01SW47#sh swi nei
      1        None           3
      3         4             1
      4         3            None
I need to remove switch 1 and just stack the current switch 3 & 4.
I intend to
     a: power off switch 1. This should cause a master election between 3 & 4.
     b: connect stack cable between switch 3 port 2 and switch 4 port 2 to enable a full duplex redundant connection.
I would like to remove switch 1 and 2 from the configuration with:
no switch 2 provision ws-c3750g-48ts
no switch 1 provision ws-c3750g-48ts
Will this cause the switch stack to reload.
As this is a production system I hope it wont
Thanks for you expected help
Richard
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Will 'no switch x provision' cause switch to reload ?
Hi Richard,
You should be good. The switch stack should not reload after removing the two unprovisioned switches.
http://www.cisco.com/en/US/partner/products/hw/switches/ps5023/products_configuration_example09186a00807811ad.shtml#stack6
JayaKrishna
Hi Richard,
JayaKrishna
Hall of Fame Super Gold
Sure but switch numbering will be puzzling to the un-initiated.
2950
