07-06-2014 11:21 PM - edited 03-07-2019 07:56 PM
I am looking for a solution to be able to connect the same devices with the same IP
Meaning:
Laptop with VMware Windows7
1st ETH interface: ip address 192.168.255.130 connected to Device A 192.168.255.129
2st ETH interface: ip address 192.168.255.131 connected to Device B 192.168.255.129
I do not want to run 2x VM's.
THX,
István
07-06-2014 11:58 PM
Try connecting Assigning a different VPN (with separate port numbers) for each Ethernet device. Is one wireless and the other wired? If so they will both connect simultaneously. I mean to say; what are you trying to do? What are these devices? What kind of LAN/VLAN/WAN are you operating on? The more data the better. Thanks....
07-07-2014 07:09 AM
Nokia 3G and 4G system modules :D
I want to be connected to both in the same time (saves time)
