11-22-2006 05:30 AM - edited 03-05-2019 12:58 PM
Hi all, can I use a normal wireless router as an AP , as I dont want it to do any routing ?
11-22-2006 06:06 AM
Hi Carl,
Yes, you can associate the wirless clients to the router. You have to create SSID for the vlans that you want to setup on the router.
-amit singh
11-22-2006 06:54 AM
Hi , I just want this router to act as an ap, can we do this ?
11-22-2006 06:58 AM
Yes you can
you can turn off routing with command
router(config)#no ip routing
than you have "simple" AP
M.
Hope that helps rate if it does
