Community Member
Wireless LAN Controller
Guru's who have implemented Wireless LAN Controller, any recommendation or watchouts based on experience.
Re: Wireless LAN Controller
I'm no guru but I deployed a few and they're slick. Super easy to configure and maintain. Check out the configuration guide, that's all I followed.
Hope it helps.
Hall of Fame Super Gold
A tall order you have there.
Like Collin, I go through the release notes of the firmware you are running to find out and bugs you might run over.
Go through the configuration guides of the firmware you are running. The list can be found here:
http://www.cisco.com/en/US/partner/products/ps6366/products_installation_and_configuration_guides_list.html
Various configuration examples can be found here:
http://www.cisco.com/en/US/partner/products/ps6366/prod_configuration_examples_list.html
Hope this helps. Please rate when you find my post helpful or applicable.
160
