WLAN <-> Catalyst <->ASA ---> Trouble
Hi there
hope, this is the right forum for my problem.
I have a AP 1240AG installed and configured with 3 SSIDs (3 VLANs). This AP is connected to a Cat6506:
---config6506---
interface FastEthernet4/23
description *** direkt WLAN Access Point ***
switchport
switchport access vlan 10
switchport trunk native vlan 10
switchport mode trunk
switchport nonegotiate
spanning-tree portfast trunk
---/config6506---
All VLANs (20 and 30) work fine, but VLAN 10 doesn't work at all.
VLAN 10 is our "main office VLAN", where the AP1240 has got it's IP Address from.
The ASA is our DHCP Server.
As soon as I connect to the VLAN 10 SSID, it seems to me that the AP does it's assoziation thing (EAP), the client get's connected, but doesn't get an IP Address.
I'm a bit "confused" about the "switchport trunk native vlan 10" statement on the catalyst, as VLAN 10 is not our "native", i.e. untagged vlan, it's tagged as every other vlan as well. But when I remove the statement, I can't connect to the AP anymore ....
Any help is highly appreciated.
Andre
Bronze
Re: WLAN <-> Catalyst <->ASA ---> Trouble
Hi Andre.
First of all, the native VLAN concept is local to each trunk, meaning that you can have VLAN10 as native VLAN on one trunk and VLAN 456 as native VLAN on another trunk.
In regard to AP, the native VLAN has to be the same as the one which is defined on the AP as being the native VLAN with the encapsulation dot1q <#> native command and it will be the one to which you ahve bound your BVI with the IP address of the AP. That is why you loose contact with the AP if you do not make VLAN 10 native.
If you connect a cabled port to VLAN 10, do a PC get IP address then?
Is ASA DHCP server for VLAN 20 and 30 as well?
Is config in AP for VLAN 10, 20 and 30 alike?
Maybe you could post the config of the AP as well?
sure, here we go:
---cut---
demucwlan01#wr t
Building configuration...
Current configuration : 5644 bytes
! Last configuration change at 13:42:22 UTC Tue Aug 4 2009 by zycko
! NVRAM config last updated at 13:35:05 UTC Tue Aug 4 2009 by zycko
version 12.3
no service pad
service timestamps log datetime localtime
service password-encryption
hostname demucwlan01
logging buffered 2000000 debugging
enable secret 5 xxxxxxxxxxxxxxxxxxx!
ip subnet-zero
aaa new-model
aaa group server radius rad_eap
server 10.17.0.37 auth-port 1812 acct-port 1813
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius rad_eap2
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authentication login eap_methods2 group rad_eap2
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
dot11 vlan-name TSC_Guest vlan 50
dot11 vlan-name TSC_Lab vlan 30
dot11 vlan-name TSC_LabMgmt vlan 20
dot11 vlan-name TSC_Main vlan 10
dot11 ssid TSC_Guest
vlan 50
authentication open
authentication key-management wpa
mbssid guest-mode
wpa-psk ascii 7 1xxxxxxxxxxxxxxxxxxx
dot11 ssid TSC_Lab
vlan 30
authentication open
mbssid guest-mode
wpa-psk ascii 7 1xxxxxxxxxxxxxxxxxxxxxxxx
dot11 ssid TSC_LabMgmt
vlan 20
authentication open
mbssid guest-mode
wpa-psk ascii 7 1xxxxxxxxxxxxxxxxxxxxxxxxx
dot11 ssid TSC_Main
vlan 10
authentication open eap eap_methods2
mbssid guest-mode
power inline negotiation prestandard source
username zycko privilege 15 password 7 xxxxxxxxxxxxxxx
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 10 mode ciphers tkip
encryption vlan 20 mode ciphers aes-ccm tkip
encryption vlan 30 mode ciphers aes-ccm tkip
encryption vlan 50 mode ciphers aes-ccm tkip
ssid TSC_Guest
ssid TSC_Lab
ssid TSC_LabMgmt
ssid TSC_Main
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.10
encapsulation dot1Q 10
no ip route-cache
bridge-group 10
bridge-group 10 subscriber-loop-control
bridge-group 10 block-unknown-source
no bridge-group 10 source-learning
no bridge-group 10 unicast-flooding
bridge-group 10 spanning-disabled
interface Dot11Radio0.20
encapsulation dot1Q 20
no ip route-cache
bridge-group 20
bridge-group 20 subscriber-loop-control
bridge-group 20 block-unknown-source
no bridge-group 20 source-learning
no bridge-group 20 unicast-flooding
bridge-group 20 spanning-disabled
interface Dot11Radio0.30
encapsulation dot1Q 30
no ip route-cache
bridge-group 30
bridge-group 30 subscriber-loop-control
bridge-group 30 block-unknown-source
no bridge-group 30 source-learning
no bridge-group 30 unicast-flooding
bridge-group 30 spanning-disabled
interface Dot11Radio0.50
encapsulation dot1Q 50
no ip route-cache
bridge-group 50
bridge-group 50 subscriber-loop-control
bridge-group 50 block-unknown-source
no bridge-group 50 source-learning
no bridge-group 50 unicast-flooding
bridge-group 50 spanning-disabled
Part 2
---cut---
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0.10
no ip route-cache
bridge-group 10
interface FastEthernet0.20
no ip route-cache
bridge-group 20
interface FastEthernet0.30
no ip route-cache
bridge-group 30
interface FastEthernet0.50
no ip route-cache
bridge-group 50
interface BVI1
ip address 10.30.0.2 255.255.255.0
no ip route-cache
ip default-gateway 10.30.0.1
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
logging trap debugging
logging facility local5
logging 10.17.0.41
radius-server attribute 32 include-in-access-req format %h
radius-server host 10.17.0.37 auth-port 1812 acct-port 1813 key 7 xxxxxxxxxxxxxxxxxxxx
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
transport preferred all
transport output all
line vty 0 4
transport input all
line vty 5 15
transport input all
sntp server 10.17.0.43
sntp server 10.17.0.44
sntp broadcast client
end
demucwlan01#
---cut---
Yes, when I connect a PC to a VLAN 10 Port it works like charm (as said, vlan 10 is our office vlan, but not the native (untagged))
Andre
Hi there
anyone any idea? This is driving me nuts ....
Andre
Purple
Deleted.
Purple
Don't see anything inherently wrong with the AP side. Nothing is specified as native on the AP side so the untagged vlan is 1 by default which is what the 6500 end should be also .
Hi glen
this is exactly what I thought as well.
Strange enough ... the EAP authentication works (i see the client as authenticated in the AP), so the network connection itself must work, the problem is just, that DHCP isn't working.
Even when I go ahead and assign a static IP out of that subnet it's not working .... really looks like that communication with the AP itself to the VLAN 10 is fine, but not for the clients ....
Bronze
Hi Andre.
Sorry for the late reply - I was off on vacation.
"VLAN 10 is our "main office VLAN", where the AP1240 has got it's IP Address from."
So you are saying that the IP address for the AP is from VLAN 10? If that is so, then you need your VLAN 10 to be the native VLAN between the switch and the AP, and you need to ahve the FastEthernet0.10 subinterface of your AP to have the native keyword in the encapsulation line. Furthermore, the bridge-group and the BVI number must be the same for all .10 subinterfaces and BVI interface.
Could you try it out?
137
