WOL configuration on L3 Catalyst 6500 & L2 2960G
Hi..
I got problem with wake on LAN software.. The software unable to ON all pc's remotely if sitting under different vlan. Everything is ok if using the same vlan. Below are the network diagram & switch configuration.
Layer 3 switch Intervlan routing configuration
ip forward-protocol udp 7
interface Vlan4
description vlan Client-WOL
ip address 172.22.51.253 255.255.254.0
ip access-group Deny_HTTP_Vlan1 in
ip helper-address 172.20.1.246
ip directed-broadcast 110
glbp 4 ip 172.22.51.254
glbp 4 priority 110
glbp 4 preempt
end
interface Vlan3
description vlan WOL-Server
ip address 172.20.31.253 255.255.255.0
ip helper-address 172.22.51.255
glbp 3 ip 172.20.31.254
glbp 3 priority 110
glbp 3 preempt
end
ip access-list extended Deny_HTTP_Vlan1
permit tcp host 172.16.30.240 172.20.1.0 0.0.0.255 eq www
deny   tcp any 172.20.1.0 0.0.0.255 eq www 443
permit ip any any
access-list 110 permit udp host 172.20.31.12 any eq echo
Layer 3 Switch (DHCP Server)
ip dhcp excluded-address 172.22.50.1 172.22.50.50
ip dhcp excluded-address 172.22.51.240 172.22.51.254
ip dhcp pool 4
   network 172.22.50.0 255.255.254.0
   default-router 172.22.51.254
   dns-server 172.16.30.7
   domain-name ump.edu.my
   netbios-name-server 172.16.30.240
Layer 2 Switch
interface GigabitEthernet0/44
description WOL-Server port
switchport access vlan 3
switchport mode access
switchport voice vlan 200
mls qos trust cos
interface GigabitEthernet0/43
description Client-WOL port
switchport access vlan 4
mls qos trust cos
After configured all the switches with the above setting, the software still cannot wake all the pc's using LAN. Base on sniffing, i can't find UDP port usage by the software. Attached here with print screen from wireshark.Screenshot.png
What should i do next to tackle the problems. Please advice guys. Tq
Everyone's tags (2)
Silver
Your WOL magic packet uses udp destination port number 40000 (decimal), so please adjust your configuration correspondingly.
Best regards,
Antonin
Base on the packet capture above, the destination port was 40000 and the sourse port was 56690. Is that the correct port? Do we need to permit both port at layer 3 switch ?
Information for the server UDP open port.
Below are my finding using 2 different software to Wake Up The Lan
DCCS Software
After  taking traffic captures, we found that DCCS software(Wake On Lan Server) uses ARP to wake  up PCs, which can not be relayed between different subnets.
Using method base on Cisco documentation : FAILED
Deep Freeze Software
Deepfreez  uses standard WOL Magic packets with Ports (65535, 80, 25, 21 and port  7) which needs to modify ACL for UDP forwarding to adapt those ports.
Using method base on Cisco documentation : SUCCESS
Hi.  Have you had any problems getting PCs on VLANs other than the Deep Freeze server to wake up during a scheduled wake in Deep Freeze?
Thanks.
I not really sure about scheduled wake in Deep Freeze because not familiar with Deep Freeze software.
Base on testing, i just using Deep Freeze WOL function to wake all the pc's (with the same and different vlan) and everything is going fine.
Problem only with the DCCS software. It's cannot WOL pc that using different vlan.
5185
