Working RTR in a 6506e Switch
I have 2 ISPs.  If one fails I want the routes to go out a different set of ASA's then the primary.  I have tried to figure out how to use the RTR command without the IP SLA because it does not exists in my IOS on the switch, so I can put the track command at the end of my route statements in the switch, but have seen a solution for this.
Does anybody have a solution to this issue?
Thank you for your help
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: Working RTR in a 6506e Switch
peter.williams@waiglobal.com
Jon,
If the primary route comes back up will it fail back to the primary route from the backup route automatically?
ex -
rtr 1
type echo protocol ipIcmpEcho 195.53.168.121
timeout 200
frequency 10
rtr schedule 1 life forever start-time now
track 123 rtr 1 reachability
ip route x.x.x.x 195.53.168.121 track 123 - this would be the primary route
ip route x.x.x.x 195.53.168.150 - this would be the backup route
Is the example above correct?
Peter
You should make the backup route a floating static so it is only put in the routing table if the primary route is removed eg.
ip route x.x.x.x 195.53.168.150 250
what will happen -
1) if the primary link is up the primary route will be in the routing table
2) if IP SLA ping fails then the primary route is removed and now the secondary route is instaled in the routing table
3) if the IP SLA ping then starts to work again the primary route is reinstalled into the routing table and the backup route is removed
Jon
What IOS are you running on your switch ?
If you are running hybrid mode please include IOS and CatOS.
Jon
IOS (tm) s3223_rp Software (s3223_rp-ADVIPSERVICESK9_WAN-M), Version 12.2(18)SXF, RELEASE SOFTWARE (fc1)
Thank you
Peter
Are you saying there are missing options or that you simply want to see a config example ie. -
Jon
Jon,
I am missing the IP SLA option but I have the RTR option.  I would like to see an example that would work for me using the RTR command, so I track the routes in my switch.  I think I do not have the IP SLA option becasue of the age of the IOS, I would hate to change the IOS just for that command.
Peter
rtr 1
timeout 200
frequency 10
ip route x.x.x.x track 123
Jon
Jon,
ex -
rtr 1
timeout 200
frequency 10
Jon,
ex -
rtr 1
timeout 200
frequency 10
Peter
what will happen -
Jon
Thank you for your help!!
440
