05-07-2007 11:33 AM - edited 03-05-2019 03:55 PM
Hi all,
I was thinking to reload a WS-3750G-24 on a prodution 3750G-24, but then i look @ config register, and note that it is as follows:
*** OUTPUT ***
WS-C3750G-24T#Show version
Switch Ports Model SW Version SW Image
* 1 24 WS-C3750G-24T 12.2(25)SEE1 C3750-ADVIPSERVICESK
Configuration register is 0xF
WS-C3750G-24T#show flash
Directory of flash:/
2 -rwx 856 Feb 26 2007 13:58:18 +00:00 vlan.dat
3 drwx 192 Mar 1 1993 00:23:04 +00:00 c3750-i5-mz.121-19.EA1c
5 -rwx 6720 May 7 2007 18:56:37 +00:00 config.text
6 -rwx 8169055 Mar 1 1993 00:29:15 +00:00 c3750-advipservicesk9-mz.122-25.SEE1.bin
7 -rwx 1955 May 7 2007 18:56:37 +00:00 private-config.text
8 -rwx 1048 May 7 2007 18:56:37 +00:00 multiple-fs
15998976 bytes total (772608 bytes free)
WS-C3750G-24T#show boot
BOOT path-list : flash:/c3750-advipservicesk9-mz.122-25.SEE1.bin
Config file : flash:/config.text
Private Config file : flash:/private-config.text
Enable Break : no
Manual Boot : no
HELPER path-list :
Auto upgrade : yes
WS-C3750G-24T#
*** END ***
As i saw in output interpreter, the system will boot the image from default boot filename "cisco17-C3750" if boot from flash fails.
This switch, dont have the option to config-register command?
This will reload fine, right ?
Best Regards,
Petr?nio
Solved! Go to Solution.
05-07-2007 11:53 AM
If it cannot read the file specified by the boot path, it will try to read the next available file: c3750-i5-mz.121-19.EA1c .
Config register can be set using:
set boot config-register 0x2
Bjornarsb
05-07-2007 12:11 PM
No Verify is not going to interrupt the process. Your config register value os 0xF which is the standard value for the catalyst 3750.
05-07-2007 11:49 AM
You will be fine.. Some of these variables can be changed using the command line. And all these variables ca be changed in Boot loader mode. For me it looks good. If you want to verify the IOS in the Switch. run the command verify flash:c3750-advipservicesk9-mz.122-25.SEE1.bin.
05-07-2007 11:53 AM
Thank u Anees,
I'll perform the reload in about 4 hours, feed back u later. (i hope).
The verify command, interrupt any type of processing ?
Best Regards,
Petr?nio
05-07-2007 12:11 PM
05-07-2007 11:53 AM
Bjornarsb
05-07-2007 04:07 PM
Reload worked fine.
Thank you very much.
Petr?nio
