Community Member
WS-3750G-48PS memory
Hi Guys,
Has anyone come across show ver memory details on 3750G-48PS as below
One of our Catalyst 3750G running software 12.2(44)SE2 shows unexpected DRAM as below
cisco WS-C3750G-48PS (PowerPC405) processor (revision F0) with 0K/12280K bytes o
f memory.
This would equate to around 11MB memory which does not seem right... Is it a known IOS bug?
this is concerning
                Head    Total(b)     Used(b)     Free(b)   Lowest(b)  Largest(b)
Processor    2835DCC    79573556    44540192    35033364    33242812    31707788
      I/O    7400000    12574720    10278080     2296640     2134340     2130624
Critical     4CF95F8     3621940          44     3621896     3621896     3621896
Critical     7C58C24      572364          44      572320      572320      572320
Appreciate your assistance...
1 ACCEPTED SOLUTION
Hi Amar, don't worry it is just a cosmectic bug fixed in newer code.
CSCsq70343    Switch memory value always show 0K when "show ver"
Release-note
Symptom:
The output of `show version' shows:
...with 0K/12280K bytes of memory.
Conditions:
No specific conditions. This happens every time with some images.
Workaround:
There is no workaround. This is a display only bug and has no effects.
please rate and close the thread accordingly.
Riccardo
1 REPLY
Release-note
Symptom:
Conditions:
Workaround:
Riccardo
444
