WS-C2924-XL extended VLAN range
does anybody know if a WS-C2924-XL supports extended VLAN range??
sh version:
IOS (tm) C2900XL Software (C2900XL-C3H2S-M), Version 12.0(5)WC8, RELEASE SOFTWARE (fc1)
regs,
Thomas
  • LAN Switching and Routing
1 ACCEPTED SOLUTION
Re: WS-C2924-XL extended VLAN range
in my previous post, the link pointed to incorrect section on the configuration guide.
this should be the correct one for Vlan Configuration guidelines:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swvlan.html#wp1029292
In brief:
A maximum of 250 VLANs can be active on supported  switches, but some models only support 64 VLANs. If VTP reports that  there are 254 active VLANs, 4 of the active VLANs (1002 to 1005) are  reserved for Token Ring and FDDI.
vlan range : 1-1005
Okay, thanks for the answer!!
Btw. the link isn't working! :-)
regs,
Thomas
In brief:
vlan range : 1-1005
Thanks a lot!!
regs,
Thomas
668
