WS-C2924M-XL IOS question
javier.moreno
I have two ws-c2924m. One is ws-c2924m-xl-a and the otheris ws-c2924-xl-en. What happens if I put the same IOS on both switches c2900xl-c3h2s-mz.120-5.WC3b.bin. Will the ws-c2924m-xl-a run the enterprise software?
Suryakant Shant
Yes, ws-c2924m-xl-a will run image c2900xl-c3h2s-mz.120-5.WC3b.bin.
So what is the diffrence between the both? Is it just the image or something else?
Yes, the difference is with features supported at the image level. Refer to below document to know additional features supported by enterprise image:
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35sa6/eescg/mascovr.htm
Thanks for the reply and link. But as far as the switch itself will the WS-C2924C-XL-A run the ios the sameway as a WS-C2924C-XL-EN. Or will the WS-C2924C-XL-A run the IOS in a cripled way?
