09-23-2008 05:22 AM - edited 03-06-2019 01:32 AM
Hi All,
Someone please clarify if we can etherchannel between WS-C2948G-GE-TX (cat OS) and 3560G-24TS (IOS). It sounds like 'YES' but just want to get openion from gurus..:-)
Thank you in advance
MS
09-23-2008 06:48 AM
Yes you can etherchannel between the two .
2948
set port channel slot/port desirable non-silent
3560
on the interface
channel-group X mode desirable non-silent
10-03-2008 08:25 PM
Thank you for your reply and apologies for the delay in getting back. So I used the link
and current config...(using 2/1 & 2/2 for port-channel)
set port channel 2/1-2 10
set trunk 2/1 nonegotiate dot1q
set trunk 2/2 nonegotiate dot1q
(by default it allows all Vlans).
The port 2/1 & 2/2 were initially set for Vlan771 than 1(that we created). I have not made any connections to other switch, but the o/p:
sh trunk:
Test-2948-S1> (enable) sh trunk
No ports trunking.
TEST-2948-S1> (enable) sh port channel
Port Status Channel Mode admin Group
2/1 notconnect on 10 417
2/2 notconnect on 10 417
Sh port 2/1
Port Name Status Vlan Duplex Speed
2/1 Test notconnect 771 auto auto
Same with 2/2 also (not showing Trunking)
Do I need to move the ports 2/1 & 2/2 to Vla1 before enable trunking..? or the Trunk pops up when I connect the other switch ports?
Thank you
MS
10-03-2008 09:09 PM
The trunk will form once the ports become up/up after being connected to another switch.
HTH,
__
Edison.
10-04-2008 10:52 AM
So the Switch ports (2/1 & 2/2) currently showing being members of VLA771 at this time does not matter. Thank you for the reply Edison. Will post how it goes.
Thank you
MS
10-04-2008 05:23 PM
When the switch isn't connected and it's configured as trunked, it will list being a member of its native Vlan.
HTH,
__
Edison.
10-06-2008 07:38 PM
Everything Looks good.
Thank you
MS
