Webcast-Catalyst9k
WS-C2960-24TC-L
Hi Sir,
I want to know that in given cisco switch ,How can I used the fibre port ,what converter(with part number) will used and what are the connectivity ,is there possible to use fibre port in given switch .how......... please also explain can we used 2 uplink as a fibre ... also if possible please send me the link so that i can see the pic.
WS-C2960-24TC-L
? 24 Ethernet 10/100 ports and 2 dual-purpose uplinks (each dual-purpose uplink port has one 10/100/1000 Ethernet port and 1 SFP-based Gigabit Ethernet port, 1 port active)
? 1 RU fixed-configuration
? LAN Base Image installed
Sunil Sharma
sunilsharma2k2@hotmail.com
Re: WS-C2960-24TC-L
its has 2 T/SFP.
this is the Product code - GLC-SX-MM=
Re: WS-C2960-24TC-L
You can either use the RJ45 port or the SFP port.
THe module that goes into the SFP port would depend upon the media you would like to terminate
The supported SFP's with 2960 are as follows
SFPs for Catalyst 2960
GLC-BX-D= 1000BASE-BX SFP, 1490NM
GLC-BX-U= 1000BASE-BX SFP, 1310NM
GLC-GE-100FX= 100FX SFP on GE SFP ports for DSBU switches
GLC-FE-100FX 100BASE-FX SFP for FE port
GLC-LH-SM= GE SFP,LC connector LX/LH transceiver
GLC-SX-MM= GE SFP, LC connector SX transceiver
GLC-FE-100LX 100BASE-LX SFP for FE port
GLC-FE-100BX-U 100BASE-BX10-U SFP
CWDM-SFP-1470= CWDM 1470 NM SFP Gigabit Ethernet and 1G/2G FC
GLC-FE-100BX-D 100BASE-BX10-D SFP
GLC-ZX-SM= 1000BASE-ZX SFP
CWDM-SFP-1490= CWDM 1490 NM SFP Gigabit Ethernet and 1G/2G FC
CWDM-SFP-1510= CWDM 1510 NM SFP Gigabit Ethernet and 1G/2G FC
CWDM-SFP-1530= CWDM 1530 NM SFP Gigabit Ethernet and 1G/2G FC
CWDM-SFP-1550= CWDM 1550 NM SFP Gigabit Ethernet and 1G/2G FC
CWDM-SFP-1570= CWDM 1570 NM SFP Gigabit Ethernet and 1G/2G FC
CWDM-SFP-1590= CWDM 1590 NM SFP Gigabit Ethernet and 1G/2G FC
CWDM-SFP-1610= CWDM 1610 NM SFP Gigabit Ethernet and 1G/2G FC
HTH, rate if it does
Narayan
Re: WS-C2960-24TC-L
Dear Sir,
Please send me the link , I want to see this also please tell what converter will be used with GLC-SX-MM= this module or it will directly connected to the port , please send the link for the confirmation
Re: WS-C2960-24TC-L
Friend,
THe GLC-SX-MM= or for that matter all other SFPs will get installed directly on the port.
The GLC-SX-MM= is a multimode fibre module and hence would require a MM fiber cable with a LC connector at one end. The other end could either be SC or LC
Have a look at this link
http://www.cisco.com/en/US/products/hw/routers/ps341/prod_module_installation_guide09186a00801cc731.html
Narayan
1022
