Webcast-Catalyst9k
WS-C2960-24TC-S and GLC-GE-100FX= module-How to configure
Hi, I am trying to install WS-C2960-24TC-S and GLC-GE-100FX= module,but i am not able to configure it, pls let me know this switch is plug n play or we need to configure it, if we need to configure it pls let me know how to configure.It would be nice if i get a link of it.
Thanks & Regards
Purple
Re: WS-C2960-24TC-S and GLC-GE-100FX= module-How to configure
Its plug and play if you don't want to manage the switch or use the hundreds of features available on the switch otherwise yes you have to configure it . Here is a guide.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_25_see/configuration/guide/swtrafc.html
dear sir
i am having switch catalyst 2960 series Sl and i have attached a fibre optic module GLC-GE-100FX my question is. Is this a plug and play as do not want to use any other feature of the switch except to give fibre optic conectivity through this switch.the modules on both the ends should be same or different modules can work and how do i come to know that it is working as in 2950 a red color lazer light comes when it is powered on but in this no light comes when powered on.
please help
Anush
dear sir
please help
Anush
Hall of Fame Super Silver
Hello Anush,
this kind of SFP makes the link a 100 Mbps fiber based link it is a special SFP.
As indicated by Leo you need at least release 12.2(37)EY to have it working
see table 8 of the link provided by Leo
Hope to help
Giuseppe
Hall of Fame Super Gold
What is your IOS version. You need at least 12.2(37)EY.
Go to the link below and look under Table 8 for more information about your switch and SFP compatibility based on IOS requirements:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html
Hope this helps.
942
