Community Member
WS-C2960-24TT-L Ports Issue
Kindly confirm the problem, of the following cisco switch. Is it a hardware failure?
WS-C2960-24TT-L
The first 8 ports of the switch are not working and in amber state and rest of the ports are working fine. Error log is attached.
Majid
1 REPLY
Re: WS-C2960-24TT-L Ports Issue
WS-C2960-24TT-L
Majid
Hi Majid,
Genrally The asic chips control 4 ports each in switch,can you share the output of show post if it has the following output
POST FAILED: FastEthernet0/21 failed front-end loopback test
POST FAILED: FastEthernet0/22 failed front-end loopback test
POST FAILED: FastEthernet0/23 failed front-end loopback test
POST FAILED: FastEthernet0/24 failed front-end loopback test
so just open a TAC case and get it replaced.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
486
