02-13-2014 12:56 AM - edited 03-07-2019 06:10 PM
one of my network switch giving issue as it is getting down for 15 minustes and then automatically start after that.This happen twice in one day.
what can be the issue as the cpu utilization is normal .
Find the attached show tech of the switch.
regards,
Wajid Dabir
Solved! Go to Solution.
02-13-2014 08:31 AM
Wajid,
Check whether the device is properly earthed. Improper earthing can cause device to reset automatically.
Ravindra
02-13-2014 01:06 AM
in tech-support file i can see "Information of Last System Crash" but i can't know it it's recently or an old crass because i don't know if the clock time is synchronized wit an ntp server.
If the time is correct with the crash info, i suggest to contact support to analyze that.
02-13-2014 01:34 AM
Hi Wajid,
As per the show tech, the switch flash does have 2 crash files, but as Pierluigi said that we don't know that these crashfiles belong to recent crashes or these are some old crash files as the timestamp gives us wrong info.
------------------ show flash: ------------------
Directory of flash:/
3 -rwx 7641 Oct 19 2013 13:27:44 +00:00 config.text
4 drwx 8192 Mar 1 1993 00:08:18 +00:00 crashinfo_ext
113 -rwx 1276 Jul 22 2013 22:46:20 +00:00 vlan.dat.renamed
114 -rwx 1216 Mar 1 1993 00:27:57 +00:00 vlan.dat
115 drwx 8192 Mar 1 1993 00:00:13 +00:00 crashinfo
223 drwx 512 Mar 1 1993 00:19:58 +00:00 c2960s-universalk9-mz.122-55.SE3
801 -rwx 7838 Jul 22 2013 23:04:27 +00:00 config.text.renamed
802 -rwx 1914 Jul 22 2013 23:04:27 +00:00 private-config.text.renamed
804 -rwx 3096 Mar 1 1993 00:02:59 +00:00 multiple-fs
803 -rwx 1918 Oct 19 2013 13:27:44 +00:00 private-config.text
Now the next step could be to delete these two crash files from the switch and wait for the next switch crash, so the next time the comes up after the crash, look for a crash file in the switch flash, if it is there, go ahead and get the crashfile decoded and you will know why the switch crashed.
Also one more thing to notice is the show version output which says:
So there are chances that the switch went down because of some issues with power. So get the power supply and the UPS checked.
In cases of crash due to internal software errors the show version says something like
"system returned to ROM by Bus error 0xyz"
Ankur
"Please rate the post if found useful"
02-13-2014 08:31 AM
Wajid,
Ravindra
02-13-2014 10:24 AM
Dear Tushar,
5 more switches are install in same network rack, how can only only switch is affected by the power issue...
Ravi, Etherning is already connected to rack in which the switch is place & it is proper.
