07-20-2012 08:38 AM - edited 03-07-2019 07:53 AM
I am in the process of updating the software on a Catalyst 3500 series switch. I deleted the old bin file and copied over the new file via xmodem.
I used this as a guide.
the image I used is:
c3500xl-c3h2s-mz.120-5.WC17.bin
Once the xmodem copy is complete I performed the following sequence of steps:
File "xmodem:c3500xl-c3h2s-mz.120-5.WC17.bin" successfully copied to "flash:c350
switch: dir flash:
Directory of flash:/
2 -rwx 430 <date> env_vars
3 -rwx 94370 <date> c3500XL-diag-mz-120-5.WC2a
4 -rwx 2648 <date> config.text
5 -rwx 109 <date> info
6 -rwx 25 <date> snmpengineid
7 drwx 640 <date> html
18 -rwx 109 <date> info.ver
19 -rwx 616 <date> vlan.dat
20 -rwx 1811584 <date> c3500xl-c3h2s-mz.120-5.WC17.bin
297984 bytes available (3314688 bytes used)
switch: set boot flash c3500xl-c3h2s-mz.120-5.WC17.bin
switch: boot
Loading "c3500xl-c3h2s-mz.120-5.WC17.bin"...c3500xl-c3h2s-mz.120-5.WC17.bin: per
mission denied
Error loading "c3500xl-c3h2s-mz.120-5.WC17.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
The last output is where I am stuck. What am I missing?
07-20-2012 09:00 AM
dumb mistake on my end.
should have been:
switch: set BOOT flash:c3500xl-c3h2s-mz.120-5.WC17.bin switch: boot
Boot is case sensitive. :-)
07-20-2012 09:07 AM
the ROMMON shell is case sensitive
you are actually setting the value for a variable named BOOT that is the meaning of the command
Hope to help
Giuseppe
