WS-C3560X-48T-L PoE?
Will a WS-C3560X-48T-L provide PoE if you put in a 715W or 1100W power supply?
Everyone's tags (6)
VIP Super Bronze
Re: WS-C3560X-48T-L PoE?
WS-C3560X-48T-L is not a POE switch
Yes, the following holds true for the 3750-X and 3560-X PoE switch models.
For PoE up to 15.4W per port, the 24 port switch requires a single 715WAC power supply. The 48 port switch requires a single 1100WAC power supply.
For PoE+ up to 30W per port, the 24 port switch requires a single 1100WAC power supply. The 48 port switch requires one1100WAC power supply and one 715WAC power supply or two 1100WAC power supplies.
With Cisco Partner status you can find this documented here.
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750x_3560x/hardware/install/notes/pwr_note.html
Can you add a 715WAC or 1100WAC power supply to a non-poe 3560X (WS-C3560X-48T-L) to add poe?
No, as stated before, WS-C3560X-48T-L is not a POE switch.
You will need the WS-C3560X-48P-L.
Hall of Fame Super Gold
Don't get offended what I've got to add.  Look at the part number you have.  If it doesn't have a "P" in the suffix, then it isn't PoE.
1232
