12-05-2006 12:35 AM - edited 03-05-2019 01:10 PM
Does this switch support an RJ45 SFP module?
I need it for uplinking to distribution layer switches.
Responses well rated :)
Gavin
12-05-2006 01:31 AM
Hi Gavin
Yes, it supports 1000BASE-T SFP-based port with RJ-45 connectors
12-05-2006 01:38 AM
do you know the part number?
12-05-2006 01:44 AM
GLC-T=
(GE SFP, RJ45 connector, 10/100/1000BT transceiver)
Hope this helps
12-05-2006 01:53 AM
Yes it supports.
I have my 3825 connncted to the 3750 with the help of the above module
Narayan
