WS-C3750-48PS-S don't start without any error
Dear all
I have a ws-c3750-48ps-s, when i power, it run without any error
But it alway hold on when show in the last line in below
File "flash:/c3750-ipservicesk9-mz.122-53.SE1.bin" uncompressed and  installed, entry point: 0x1000000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version  12.2(53)SE1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 12-Mar-10 15:50 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
Initializing flashfs...
flashfs[1]: 1 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 15998976
flashfs[1]: Bytes used: 12713984
flashfs[1]: Bytes available: 3284992
flashfs[1]: flashfs fsck took 1 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Checking for Bootloader upgrade.. not needed
POST: CPU MIC register Tests : Begin
POST: CPU MIC register Tests : End, Status Passed
POST: PortASIC Memory Tests : Begin
POST: PortASIC Memory Tests : End, Status Passed
POST: CPU MIC interface Loopback Tests : Begin
POST: CPU MIC interface Loopback Tests : End, Status Passed
POST: PortASIC RingLoopback Tests : Begin
POST: PortASIC RingLoopback Tests : End, Status Passed
Waiting for Stack Master Election...
POST: Inline Power Controller Tests : Begin
POST: Inline Power Controller Tests : End, Status Passed
POST: PortASIC CAM Subsystem Tests : Begin
POST: PortASIC CAM Subsystem Tests : End, Status Passed
POST: No Cable found on stack port 1
POST: No Cable found on stack port 2
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
A summary of U.S. laws governing Cisco cryptographic products may be  found at:
export@cisco.com.
cisco WS-C3750-48P (PowerPC405) processor (revision J0) with 131072K  bytes of memory.
Processor board ID CAT1015R25W
Last reset from power-on
1 Virtual Ethernet interface
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:17:95:63:21:80
Motherboard assembly number     : 73-9675-11
Power supply part number        : 341-0029-04
Motherboard serial number       : CAT10142AT8
Power supply serial number      : DTH1011C59Y
Model revision number           : J0
Motherboard revision number     : A0
Model number                    : WS-C3750-48PS-S
System serial number            : CAT1015R25W
SFP Module assembly part number : 73-7757-03
SFP Module revision Number      : A0
SFP Module serial number        : CAT10141HKT
Top Assembly Part Number        : 800-25858-03
Top Assembly Revision Number    : F0
Version ID                      : V05
CLEI Code Number                : COM1W00ARB
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3750-48P       12.2(53)SE1            C3750-IPSERVICESK9-M
Now it hold
Can you help me?
1 REPLY
Re: WS-C3750-48PS-S don't start without any error
Could be a problem with your keyboard, try disabling your num lock.
if possible check your console memory status.
683
