04-23-2009 11:20 AM - edited 03-06-2019 05:21 AM
I am trying to figure out why I am getting these error messages on my 3750E switch:
Apr 23 18:34:39: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Apr 23 18:44:39: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Apr 23 18:54:40: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Apr 23 18:58:46: %SYS-5-CONFIG_I: Configured from console by gstewart on vty0 (10.24.133.149)
Apr 23 19:04:40: %SFF8472-5-THRESHOLD_VIOLATION: Te1/0/1: Tx power low alarm; Operating value: -32.2 dBm, Threshold value: -12.2 dBm.
Any suggestions?
04-23-2009 02:29 PM
Can you please post the result of the following commands:
sh post
sh environ alarm
sh run interface Te1/0/1
04-23-2009 02:43 PM
everything passed in the show post.
no issues with the env
IT-ROOM-264-IDF# sh run interface Te1/0/1
Building configuration...
Current configuration : 128 bytes
interface TenGigabitEthernet1/0/1
switchport mode trunk
channel-group 14 mode on
end
IT-ROOM-264-IDF#show interface Te1/0/1
TenGigabitEthernet1/0/1 is down, line protocol is down (err-disabled)
Hardware is Ten Gigabit Ethernet, address is 0024.974e.8bb5 (bia 0024.974e.8bb5)
MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
reliability 253/255, txload 1/255, rxload 1/255
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is 10GBase-LR
input flow-control is off, output flow-control is unsupported
Last input never, output 04:17:08, output hang never
Queueing strategy: fifo
Output queue: 0/0 (size/max)
0 packets input, 144 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
5 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
19 packets output, 1216 bytes, 0 underruns
0 output errors, 0 collisions, 5 interface resets
04-23-2009 05:09 PM
How about "sh interface Ten1/0/1 trans detail"?
04-24-2009 04:19 AM
IT-ROOM-264-IDF#sh interface Ten1/0/1 trans detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, + : high warning, - : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
High Alarm High Warn Low Warn Low Alarm
Temperature Threshold Threshold Threshold Threshold
Port (Celsius) (Celsius) (Celsius) (Celsius) (Celsius)
Te1/0/1 32.7 74.0 70.0 0.0 -4.0
Voltage Threshold Threshold Threshold Threshold
Port (Volts) (Volts) (Volts) (Volts) (Volts)
Te1/0/1 0.00 3.63 3.46 3.13 2.96
Optical High Alarm High Warn Low Warn Low Alarm
Transmit Power Threshold Threshold Threshold Threshold
Port (dBm) (dBm) (dBm) (dBm) (dBm)
Te1/0/1 -2.0 4.5 0.5 -8.2 -12.2
Receive Power Threshold Threshold Threshold Threshold
Te1/0/1 -4.8 4.5 0.5 -14.1 -18.4
IT-ROOM-264-IDF#
04-26-2009 03:56 PM
Don't know with the other's opinion but your module (Ten 1/0/1) is has triggered an alarm after exceeding the lower treshold limit of -12.2dBm.
My recommendation is to get the module RMA-ed.
