09-18-2007 09:18 PM - edited 03-05-2019 06:33 PM
We have a stacked 3750 that has RPS supplying but the main power is fine. Is there a reason why it's not failing back over? Is there a way to force this?
thx
nj02ga03oas44#show env all
FAN is OK
TEMPERATURE is OK
Temperature Value: 36 Degree Celsius
Temperature State: GREEN
Yellow Threshold : 56 Degree Celsius
Red Threshold : 66 Degree Celsius
POWER is FAULTY
RPS is SUPPLYING
nj02ga03oas44#
Cisco IOS Software, C3750 Software (C3750-IPBASEK9-M), Version 12.2(25)SEE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Fri 28-Jul-06 12:55 by yenanh
Image text-base: 0x00003000, data-base: 0x010272D8
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(25r)SEE4, RELEASE SOFTWARE (fc1)
Solved! Go to Solution.
09-19-2007 05:38 AM
Switch will not auto sense that the power came back on. Switch has to be reload to reconnect to main power.
~JG
Please rate helpful posts
09-19-2007 05:38 AM
~JG
