WS-C3750X-24T-L no switchport command
We have WS-C3750X-24T-L with c3750e-universalk9npe-tar.152-1.E1.tar IOS when i try to cammand no switchport it is not accepting the command any license required for this command.
Hall of Fame Super Gold
Your switch probably has IP Base license.
"no switchport" is an IP Services feature command.
Check the license you use. It is likely lanbase, so switch does not accept any L3 commands. You need ipbase.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
Thanks for your replay with out ipbase license how to configure no switchport command any other options and commands suggest me.
You cannot. Lanbase license does not allow you to use any L3 features, they are blocked.
Kind Regards,
Ivan Shirshin
Depends on what you license your 3750X has.  If you have IP Base, then you need to contact your authorized Cisco reseller and they can organize to get a permanent IP Services license installed.
In the meantime you can get a 30-day Evaluation license enabled.
307
