Webcast-Catalyst9k
WS-C3750X-24T-L with EIGRP
The model WS-C3750X-24T-L is only Lan Base. We need this switch to use EIGRP Protocol. Does it exist a License for supportting IP Base o IP Services Feature Set?
Expect for your comments.
Mitchell
Everyone's tags (1)
VIP Super Bronze
You can upgrade it to IP Base or IP Services.  IP Base gives you only EIGRP Stub.  If you want full EIGRP, OSPS, BGP, etc... support you need IP services.
http://www.cisco.com/en/US/products/ps10745/prod_models_comparison.html
I am trying the IP Services in the WS-C3750X-24T-L with a Demo License.
I have the following message:
Index 1 Feature: ipservices
        Period left: 8  weeks 4  days
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
        License Priority: None
        License Count: Non-Counted
Index 2 Feature: ipbase
        Period left: 0  minute  0  second
Index 3 Feature: lanbase
        Period left: Life time
        License Type: Permanent
        License State: Active, In Use
        License Priority: Medium
Any of you knows how to change IP Service License from "Not in Use" to "In Use"?
Mitchell
Green
http://www.cisco.com/en/US/docs/ios/csa/command/reference/csa_book.html
Try going in to config t
switch(config)# license accept end user agreement
See if that changes the status to in use.
Alex
Regards, Alex. Please rate useful posts.
VIP Super Bronze
Re: WS-C3750X-24T-L with EIGRP
Mitchell,
Try this command and then reboot:
license boot level ipservices
Alex,
According to the link you provided, the command license accept end user agreement is only available in IOS 15 and later for ISR G2 routers.
795
