WS-C3750X-24T-S IP Base upgrade to IP Services upgrade license
reycapoy
Good Day,
     I would like to ask for assistance if we are getting the correct SKU for a license upgrade of WS-C3750X-24T-S.  Please see details below:
C3750X-LIC=   Product Activation Keys for 3750-X Series
C3750X-24-S-E C3750X-24 IP Base to IP Services Paper License
Thanks.
2 Accepted Solutions
Hi Rey,
You don't need paper license.  All you need is
L-C3750X-24-S-E=
C3750X-24 IP Base to IP Services E-License
Once you pay for the license, they will send you a very small file.  You can then uploaded it to your switch and install it.
Hi Rey,
Please rate and close the treat, so other people can benefit from it.
Reza
8 Replies 8
Ganesh Hariharan
Rey Capoy wrote:
Good Day,
Thanks.
Hello Rey,
Correct me if i have misundertood your query ...Are you asking do we requirea license from ipbase to ipservices .?? Then answer is yes software license is required only for upgrading to a different feature set, such as upgrading from the IP Base to the IP Services feature set.
Hope to help !!
Ganeshh Iyer
Hi Ganeshh,
      Good Day.  Sorry for my late response.  We don't have work on Saturdays and Sundays. Actually partially we are right.  The client needs an upgrade from IP Base to IP Services. What I need to ask if we are getting the right SKU's as stated above.
   Thanks.
Hi Rey,
L-C3750X-24-S-E=
Hi Reza,
       Noted and Thank you very much.
Hi Rey,
Reza
Hi Reza,
   I am not sure if I am doing it correctly. I click the button [Corect Answer].  Is that the way to rate this thread?  How do I close it as well.
Thanks.
Hi Rey,
You did all correct.
If you look at the top of the treat, you see this message:
This Question is Answered
Thanks for the rating
Hi Reza,
     Yes, I see it. Thanks ang Best Regards.  Expect all five stars from me. -:)
