08-10-2012 12:28 PM - edited 03-07-2019 08:16 AM
When issuing the show mac address-table address aaaa.aaaa.aaaa on a WS-C4507R, I received the next output. what "static ip,ipx,assigned,other
Switch" means?
Unicast Entries
vlan mac address type protocols port
1 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
6 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
7 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
10 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
119 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
120 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
121 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
122 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
128 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
129 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
130 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
131 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
132 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
133 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
134 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
135 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
139 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
140 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
142 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
143 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
184 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
189 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
190 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
197 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
228 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
229 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
230 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
231 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
232 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
233 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
234 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
235 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
236 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
237 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
238 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
239 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
240 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
241 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
242 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
243 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
244 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
360 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
362 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
364 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
368 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
372 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
374 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
380 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
384 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
388 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
411 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
700 aaaa.aaaa.aaaa static ip,ipx,assigned,other Switch
Solved! Go to Solution.
08-13-2012 06:14 PM
Hi Esteban,
It is normal to have this output. Example if there says IPX that just means that is capable is not saying that is receiving IPX.
Unicast Entries
Description:
static means that the mac address was configured or hardcoded manually on that port.
dynamic means that the port learned the mac address dynamically.
For the MAC address table entries that are used by the routed ports, the routed port name is displayed in the "vlan" column not the internal VLAN number.
The keyword definitions for the protocol variable are as follows:
Please inform me if you need more detail
Aru
08-13-2012 06:14 PM
Hi Esteban,
Unicast Entries
Description:
Aru
08-17-2012 11:51 AM
But the same Mac Address entry for all condigured VLANs?
08-19-2012 10:38 AM
Hi Esteban,
From this output, this type field indicates that this MAC address aaaa.aaaa.aaaa configured statically on swtich.
Example:
To display the static MAC address table entries only, use the show mac-address-table static command.
show mac-address-table static [address mac_addr | interface type number | protocol protocol | vlan vlan_id]
Switch# show mac-address-table static
Unicast Entries
1 0030.94fc.0dff static ip,ipx,assigned,other Switch
Fa6/1 0030.94fc.0dff static ip,ipx,assigned,other Switch
Fa6/2 0030.94fc.0dff static ip,ipx,assigned,other Switch
Please clarify the below points,
1. What is the HW and SW verion on this switch?
2. Is there any other switch do you see this same behavior?
3. Did you do any change? Is it first time when you see this issue on this node?
Aru
08-19-2012 12:34 PM
Just inspect the running config for any static mac entries. U'll find a non-specific static entry configured for the "aa....aa" MAC.
The previous reply explains it all
