WS-C6509-E power-output-mode
Hello
I have a system alert on WS-C6509-E, but i cant find the reason for this alert. The power stats are OK and exactly the same.
system minor alarm on power-supply 2 power-output-mode
Can someone please explain what does this alert mean?  And what does the "low/high" output mode means.
Thank you
sw#sh environment alarm status
environmental alarms:
sw2#sh power
system power redundancy mode = redundant
system power total =     2671.20 Watts (63.60 Amps @ 42V)
system power used =      1631.70 Watts (38.85 Amps @ 42V)
system power available = 1039.50 Watts (24.75 Amps @ 42V)
                        Power-Capacity PS-Fan Output Oper
PS   Type               Watts   A @42V Status Status State
1    WS-CAC-6000W       2671.20 63.60  OK     OK     on
2    WS-CAC-6000W       2671.20 63.60  OK     OK     on
sw#sh env status power-supply 2
power-supply 2:
  power-supply 2 fan-fail: OK
  power-supply 2 power-input: AC low
  power-supply 2 power-output-mode: low
  power-supply 2 power-output-fail: OK
sw#sh env status power-supply 1
power-supply 1:
  power-supply 1 fan-fail: OK
  power-supply 1 power-input: AC low
  power-supply 1 power-output-mode: low
  power-supply 1 power-output-fail: OK
Everyone's tags (2)
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
The error message basically
The error message basically means that you've got two 6K power supply.  Each power supply requires TWO power input/feed and, in your case, only ONE is functional.
It may not seem much but some line card, like 67XX 10 Gbps line card, will not boot up unless there is adequate power supplied.
1 REPLY
102
