05-31-2010 08:11 AM - edited 03-06-2019 11:21 AM
WS-C6509 switch supports two models of power supply in the same chassis?
for exemplo :
PS Type Watts A @42V Status Status State
1 WS-CAC-3000W 1171.38 27.89 - - off
2 WS-CAC-4000W-INT 3795.12 90.36 OK OK on
Note: PS2 capacity is limited to 2940.00 Watts (70.00 Amps @ 42V)
when PS1 is not present
Solved! Go to Solution.
05-31-2010 11:15 AM
If you use 2 PSUs with the different wattage in the same chassis then you can not use them in redundant mode which is default.
You can use 2 different PSUs in the same chassis in combined mode only.
Mode info here:
Reza
05-31-2010 11:15 AM
Mode info here:
Reza
05-31-2010 03:26 PM
It will work ... as long as the bigger PSU doesn't fail. In regards to the status of the line cards will depend on what they are.
