Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
WS-SUP720-3B - 2 Ten Gigabit Interfaces
hi,
I would like to know why does show version on WS-SUP720-3B shows
4 Virtual Ethernet interfaces
72 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
whereas in I can only see 48 port Gigabit Ethernet Interfaces and 2 Gigabit Interfaces (i.e. SFP modules).
Regards.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: WS-SUP720-3B - 2 Ten Gigabit Interfaces
Hello New,
to see physical ports you can use:
sh ip int br
sh int status
RT-TO-CRN-SF-E-1#sh int status
Port Name Status Vlan Duplex Speed Type
Gi3/1 Link -> SW-TO-CRN- connected 10 full 1000 1000BaseSX
Gi3/2 disabled 1 full 1000 1000BaseSX
Gi3/3 Failover link -> R connected 901 full 1000 1000BaseSX
Gi3/4 Stateful link -> R connected 902 full 1000 1000BaseSX
Gi3/5 Link FT x CSM connected 999 full 1000 1000BaseSX
Gi3/6 Link #1 -> RT-TO-C connected routed full 1000 1000BaseSX
Gi3/7 Link #2 -> RT-TO-C connected routed full 1000 1000BaseSX
Gi3/8 Link L1/L2 -> RT-T connected routed full 1000 1000BaseSX
Fa4/1 Link -> SW-TO-CRN- connected trunk a-full a-100 10/100BaseTX
Fa4/2 disabled 1 half auto 10/100BaseTX
Hope to help
Giuseppe
Hello New,
compare
sh version
sh module
Hope to help
Giuseppe
Still no clue..
SHOW VERSION
cisco WS-C6509-E (R7000) processor (revision 1.4) with 458720K/65536K bytes of m
emory.
Processor board ID SMC123600CH
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
SHOW MODULE
Mod Ports Card Type Model Serial No.
1 6 Firewall Module WS-SVC-FWM-1 SAD123502XJ
2 1 Application Control Engine Module ACE20-MOD-K9 SAD123500YF
3 8 Network Analysis Module WS-SVC-NAM-2 SAD12260338
4 48 CEF720 48 port 10/100/1000mb Ethernet WS-X6748-GE-TX SAL12394FTB
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL12394QLZ
6 1 Application Control Engine Module ACE20-MOD-K9 SAD123500X9
7 8 Intrusion Detection System WS-SVC-IDSM-2 SAD11050B09
Hello New,
be aware that all services modules have internal connections via GE ports:
see this on one of my switches:
sh module
2 6 Firewall Module WS-SVC-FWM-1 SAD085008DY
3 8 8 port 1000mb ethernet WS-X6408-GBIC SAD03295602
4 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL0543DMSM
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAD0851097J
6 4 SLB Application Processor Complex WS-X6066-SLB-APC SAD071601PG
7 16 SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX SAL08311CYB
8 48 48 port 10/100 mb RJ-45 ethernet WS-X6248-RJ-45 SAD03290204
9 1 Application Control Engine Module ACE20-MOD-K9 SAD1112028
sh ethercha sum
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3 S - Layer2
U - in use f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
Number of channel-groups in use: 4
Number of aggregators: 4
Group Port-channel Protocol Ports
1 Po1(SU) - Gi5/1(P) Gi5/2(P)
2 Po2(RU) - Gi3/6(P) Gi3/7(P)
262 Po262(SU) - Gi6/1(P) Gi6/2(P) Gi6/3(P) Gi6/4(P)
271 Po271(SU) - Gi2/1(P) Gi2/2(P) Gi2/3(P) Gi2/4(P)
Gi2/5(P) Gi2/6(P)
each FWSM uses 6 GE, the CSM uses 4 GE and the ACE is not shown here for security reasons but you can expect it to use more then 6 ports.
in my case
RT-TO-CRN-SF-E-1#sh ver | inc Ethernet
28 Virtual Ethernet/IEEE 802.3 interfaces
96 FastEthernet/IEEE 802.3 interfaces
36 Gigabit Ethernet/IEEE 802.3 interfaces
1 Ten Gigabit Ethernet/IEEE 802.3 interface
RT-TO-CRN-SF-E-1#
I have only 8 GE external interfaces:
4 used by CSM
6 used by FWSM
ACE will use 8 GE or 1 Tengiga
Hope to help
Giuseppe
So which entry can I use to see the physical ports and the media type.
Regards.
Hello New,
sh ip int br
sh int status
Hope to help
Giuseppe
849
